Zetec Turbo on Megasquirt, new Turbo arrived. GT2871R :P
Old Jan 28, 2008 | 10:41 PM
Gregor's Avatar
Gregor
Default Zetec Turbo on Megasquirt, new Turbo arrived. GT2871R :P
Well, here's some pics of my ZVH rst project.
Work done so far include full respray , bigger brakes , 2.0 ZVH turbo engine but still running MFI
Just started to convert to EFI using megasquirt yesterday.
Here's some pics
Old Jan 28, 2008 | 10:44 PM
bonus_boy's Avatar
bonus_boy
looks pretti kool tha!
they rondels?
Old Jan 28, 2008 | 10:49 PM
Very nice ,saw this at landgraaf
Old Jan 28, 2008 | 10:51 PM
Gregor's Avatar
Gregor
Took off the head and all the MFI stuff already...
Waiting for the EFI head i'm working on at the moment
So much space over the gearbox... so finally some room for my oilcooler..
Old Jan 28, 2008 | 10:53 PM
Gregor's Avatar
Gregor
they rondels?
Borbet's
Old Jan 29, 2008 | 08:02 AM
Gregor's Avatar
Gregor
Inletports On the EFI head are ready to go.... Have to find me some time to do the exhaustports this week and order a new gasker and bolts to put the head on .
Old Jan 29, 2008 | 08:06 AM
Willem's Avatar
Willem
Nice job m8!
Old Jan 29, 2008 | 08:34 AM
Gregor's Avatar
Gregor
Originally Posted by Willem
Nice job m8!
Thnx
Received the MS kit last week.
The brains...with boostcontrol, launchcontrol an 4 bar mapsensor
Inovate Wideband lambda kit with display..
Nice wiring loom...
boostcontrolvalve, AIT sensor and TPS...
I won't be getting bored the upcoming weeks
Old Jan 29, 2008 | 10:20 AM
RST Appie's Avatar
RST Appie
Nice project Gregor.
Old Jan 29, 2008 | 04:22 PM
Berry RST's Avatar
Berry RST
www.powerkings.nl
finally......
It's about time
The space near the gearbox is great!!! I know!!! Plenty of room for a big filter and oil-cooler!
And how are things with the downpipe??
Cheers Berry
Old Jan 29, 2008 | 09:09 PM
Mr.T's Avatar
Mr.T
Wow after all that time a topic hehe. Good luck with the build mate
Old Jan 29, 2008 | 10:48 PM
Dan's Avatar
Dan
Looks perfect on the Borbet's! Lovely wheel! Really suit the car
Old Jan 30, 2008 | 05:38 PM
morley88's Avatar
morley88
Finding my feet
Hiya mate, wots involved in swapping to efi, and what are the advantages, other than space above the gearbox?
Old Jan 30, 2008 | 07:25 PM
fezzajsy's Avatar
fezzajsy
all the best with it m8
Old Jan 31, 2008 | 09:04 AM
Gregor's Avatar
Gregor
The advantage is you can run far more boost because you have the abitily to put in much more fuel.
Involved is : you need a efi head, injectors, fuel rail, frst/efi or stand alone management, wiring loom adapted, efi inlet, EFI flywheel with cps and some more .... lots of Mfi--> Efi comversion topics here on PF ..
Old Jan 31, 2008 | 09:06 AM
Gregor's Avatar
Gregor
Originally Posted by Berry RST
finally......
It's about time
Cheers Berry
Downpipe has yet to be constructed, first alll the headwork and then the downpipe.
Have to work on it anyways because of the fitment of thme lambda sensor..
Old Jan 31, 2008 | 02:31 PM
Gregor's Avatar
Gregor
injectors to be used....
380 cc rover injectors
anyone know to what power these can be used??
Old Jan 31, 2008 | 05:38 PM
morley88's Avatar
morley88
Finding my feet
Gregor,
so wots the spec of yours?? what management were you using etc...
also just out of interest, wot gearbox do you use??
thanks
Old Feb 1, 2008 | 12:40 AM
Gregor's Avatar
Gregor
Gregor,
thanks
Hej,
spec was : 2.0 ZVH with accrelite pistons CR 8:1
standard head with kent 35
MDS chip, k&n, scorpion 2.5"
Samco's, alu rad, cos intercooler
adj cam poulie, -31 acruator.
AP fast road clutch.
New spec: As old but with AP paddle clutch
Megasquirt 1V3 ecu with wide band lambda
2wd cosworth turbo
13 row oil cooler
At home ported and polished efi head.
hopefully a grs intercooler if i ever get it send here,,, :S
Already driving it with a stage 1 box from the gearboxman but wondering how long it wil cope with the increased power..
cheers
Old Feb 1, 2008 | 08:57 AM
Maki's Avatar
Maki
good topic I'm doing the same thing? ZVH with MS
Will be interesting to read your thread
Old Feb 3, 2008 | 05:23 PM
Gregor's Avatar
Gregor
Exhaust side of the head all done now... zo waiting for bolts and gastket to put it on..
Also made some bonnet spacers to help cool the engine... and looks nice as wel
Old Feb 3, 2008 | 05:35 PM
Maki's Avatar
Maki
What bolts and gasket are you planing to use?
I've used felpro and standard RST head bolts as I was advised to use stretch ones, but to use them I had to machine the head in the place where bolts sit to go deeper by 8 mm
Old Feb 3, 2008 | 05:53 PM
Gregor's Avatar
Gregor
I'm Going to use a felpro gasket and cougar stretch bolts wich have to be shortened by about an inch or so.
Had it like this the last 2 years on my mfi ZVH.
Old Feb 3, 2008 | 06:03 PM
Maki's Avatar
Maki
Hm, never heard of that way, but should be OK
By the way did you study MS wiring already?
Old Feb 3, 2008 | 06:34 PM
Mr.T's Avatar
Mr.T
@ maki.
The wiring for the MS isnt that difficult mate. They are al marked.
Old Feb 3, 2008 | 07:45 PM
Maki's Avatar
Maki
Originally Posted by JeroentjeRS
@ maki.
It's not that simple when you have no marked wire harnes I'm making it from old EFI loom and I'm using no relay board
And at the moment I'm stuck with fidle valve so was wondering maybe Gregor has thought about it already.
Old Feb 3, 2008 | 08:01 PM
Mr.T's Avatar
Mr.T
Ah ok. Why didn't you bought the MS loom then? it isnt that expensive.
Old Feb 3, 2008 | 08:12 PM
Maki's Avatar
Maki
This way thinking I should have bought cossie and get everything sorted in one package ... but that wasn't the point if you know what I mean
Old Feb 3, 2008 | 08:19 PM
Gregor's Avatar
Gregor
I bought the MS loom so its all marked....
Old Feb 3, 2008 | 08:47 PM
Maki's Avatar
Maki
What fidle valve are you gonna use?
Old Feb 6, 2008 | 09:22 AM
Gregor's Avatar
Gregor
i'll use the 2i valve....
Old Feb 7, 2008 | 04:43 PM
Gregor's Avatar
Gregor
Did some work again...
reground the valves/valveseats, put on new valvestemseals, put on the springs+valves,cam, thermostathousing and adj pulley.
Weird thing is the cam looks a littte off-set... but seems to have ran like this the whole time so shouldn't be a problem.
Got the bolts for the head and some other gaskets and nuts from the ford dealer.
Now waiting for the headgasket from burton so all can go on the bottom end
Old Feb 7, 2008 | 05:21 PM
Maki's Avatar
Maki
It is like that for one simple reason, this way lifters rotate all the time and don't wear in one place
Old Feb 7, 2008 | 08:28 PM
jamie rst's Avatar
jamie rst
Old Feb 8, 2008 | 12:00 AM
Gregor's Avatar
Gregor
Reason why i asked is because with my old mfi head with kent 35 cam the lobes were about in the middle of the follower holes so recconed it should be like that...... but learned something again..
Old Feb 9, 2008 | 08:07 AM
wess-rs's Avatar
wess-rs
greggie, wel done mate when wil it be finest..??
keep up the good work
Old Feb 9, 2008 | 06:07 PM
lee s1's Avatar
lee s1
looking good
Old Feb 10, 2008 | 06:24 PM
Gregor's Avatar
Gregor
Worked on the ports off the inlet manifold to match the head and placed it on the head together with e fuelrail and injectors ....
Old Feb 10, 2008 | 06:32 PM
Mr.T's Avatar
Mr.T
Is this car still not finished
Nice work. Now get that thing runnig
Old Feb 13, 2008 | 06:30 PM
Gregor's Avatar
Gregor
While waiting for the headgastket , started to renew the brakelines as something wasn't right in the lines that were there.... the brakes didn't respond verry well so all new lines in there with a wilwood brake bias valve for the rear..
some pics..
When the cos brakes are reconditioned they're coming back on with the braided hodes
