smoking frst
the wife`s frst has abit of a smoke problem it`s worse after you`v been driving and pull up at a junction but it also does it when your driving not has bad but not all the time.i changed the valve stem seals last summer and turbo looks in pritty good condtion.were or what could be causing problem?
check the oil return pipe hasn't collapsed inside, if so this will restrict the flow of oil back to the sump and backs up into the turbo causing the oil to burn through the exhaust!
Steve Escos
Oct 1, 2015 06:57 AM
