flashed by a gatso.anyway out that works?
basically got flashed on sunday morning 07.48 for doing 48 in a 40. got the letter this morning. place called langsett near sheffield. i don't recall seeing a 40 sign but i am going back up tomorrow to check.
anyway out that actually works?
thanks,bryan
thanks,bryan
you could try removing all the '40' speed signs then take photos saying it wasnt signposted. although technically if its not sign posted its a 30 unless stated otherwise so that wouldnt work.
hard luck .
hard luck .
There are 'ways out'. Mainly due to errors with how, or why the NIP was issued. But unless you're willing to cough up big time for a fancy lawyer, it's going to be cheaper to just cop for it.
To do nothing is not a good idea.
The system is set up to make it very costly to go to court to challenge it. If you kick up any fuss about the NIP it goes to court and you run the risk of a much larger fine.
IMHO unless you were doing a speed which would get you banned it's just not in your interest to challenge it.
If you've got the time have a good look around www.pepipoo.com - silly name, great site.
Dan
Dan
Originally Posted by fuzzy
you could try removing all the '40' speed signs then take photos saying it wasn't signposted. although technically if its not sign posted its a 30 unless stated otherwise so that wouldn't work.
Originally Posted by DangerousBryan
if i do ignore it,will they send another out? i now they only have 6 weeks or something to fine me.is that right?
van_dogg_pavvy
Mar 3, 2016 09:30 AM
