WooHoo..new wheels arrived and a question!
Old Jan 22, 2008 | 06:47 PM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
Default WooHoo..new wheels arrived and a question!
Cheers Doug..L8
5 x ready to be painted 17 x 8 OZ mag superlites No pics until done but same as my sig wheels but bigger
Question 1......can i paint these with aerosol..i know you cant powder coat magnesium...so will it be ok????
Question 2......on each flat bit where the stickers go there are 4 tiny threaded holes,what they for?
Old Jan 22, 2008 | 06:52 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Question 1: No idea
Question 2: Little holes like these are to bolt on brake cooling discs
Old Jan 22, 2008 | 06:56 PM
gus's Avatar
gus
yeah, sure they are for cooling ducts
b9kos how many sets of wheels you got now?
Old Jan 22, 2008 | 06:58 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Only three now Sold the old skool comps, but may be getting them back
The 17inch OZ mags in the pic above were borrowed from a friend so i could see what my Ripleys would look like
Old Jan 22, 2008 | 07:02 PM
Moose 130's Avatar
Moose 130
I had my magnesium wheels powder coated......
Old Jan 22, 2008 | 07:11 PM
gus's Avatar
gus
think it depends on how much magnessium there is in the wheel
dont think i would powder coat them oz's
SteveB's Avatar
SteveB
I had my old mag rims painted in a std bodyshop with "normal" paint
Old Jan 22, 2008 | 07:14 PM
trevCOSS's Avatar
trevCOSS
the wheel you see in the pic on rich car is powdercoated as are the other 5 that the owner of the wheel has, with no problems.
Old Jan 22, 2008 | 07:27 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Aerosol paint will be fine as long as its got a good key.
Old Jan 22, 2008 | 07:32 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
areosol would look shit imo ,.
why not get the blasted with a mild meida , or walnut shells or summit and 2 k paint them ,
fuck knows u got the money ?
Old Jan 22, 2008 | 07:33 PM
lamb chops's Avatar
lamb chops
I was told its fine to powercoat but they have to be baked for a long (couple of days) period to get the air out. Had my my centres done and no problems.
Old Jan 22, 2008 | 07:34 PM
lamb chops's Avatar
lamb chops
Old Jan 22, 2008 | 07:42 PM
MAD EVO 4's Avatar
MAD EVO 4
we powder coat all our mag wheels, weather rd going wheels or racing wheels
Old Jan 22, 2008 | 07:43 PM
Physio's Avatar
Physio
I gave my CSL rims in to be powder coated today - dont they have magnesium in them?
I'm sure they'll be ok
Old Jan 22, 2008 | 07:49 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Beefy
why would they look shit? when i done craig todds old wheels which were the same as phils i done them with aerosol and they looked spot on
heres a pic
Old Jan 22, 2008 | 07:57 PM
-beefy-'s Avatar
-beefy-
yeah but ive seen craigs and they look shit ,
probably the shonky workmanship of the painter
just thinking if hes going to be blatting about the roads and track , 2k may stand up better ,
i mean craigs aint a comparision , it gets driven evrywere at tem miles an hour and he only has it out three times a year
how u doing fella
Old Jan 22, 2008 | 08:47 PM
Dicko&Vacant
phil on a track come on beef
Old Jan 22, 2008 | 08:59 PM
Twellsie's Avatar
Twellsie
you can powder coat mag, its down the the cleaning process first, also genrally helps if you use an alkaline chromate process such as Alochrome which prevents most of the porosity problrms caused by mag castings
Old Jan 22, 2008 | 09:00 PM
Deleted by Request
Former Sponsor
...so do i primer then paint then laquer..or just use a good wheel spray?......fuck paying big money ...its a rally car
Old Jan 22, 2008 | 09:40 PM
Rippers's Avatar
Rippers
Monte Geek
Just prime and paint them, don't rub them down if possible and take any of the protective coating off as Mag wheels have a anodised like coating from factory.
Old Jan 22, 2008 | 11:05 PM
-beefy-'s Avatar
-beefy-
on second thoughts
areosol will do just fine phil !
Old Jan 22, 2008 | 11:33 PM
BigErn's Avatar
BigErn
Phil, if they in decent nick then a paint/bodyshop wont charge much to do them in 2k mate.
Old Jan 22, 2008 | 11:45 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
2K gets my vote as well, aersol is such a piss weak mix of paint its just not really any good, it will look ok initially but wont last.
Old Jan 23, 2008 | 12:24 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Old Jan 23, 2008 | 08:58 AM
Deleted by Request
Former Sponsor
..they are bead blasted ready....i thought when i saw 2k thats how much i should spend on painting them
...incidentally as they are all bead blasted can you just paint the face or does where the tyre fits need doin aswell and backs?...
Old Jan 23, 2008 | 02:14 PM
Deleted by Request
Former Sponsor
BTTT
Old Jan 23, 2008 | 02:58 PM
Dan's Avatar
Dan
Depends on what aerosol but it can be fine!!
Old Jan 23, 2008 | 03:25 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
Originally Posted by EsCosRacer
body shop phil.....have em properly painted !! Why 17 and not 18s ?
r we gonna see u on track with this ?
18's are no good on a sapphire,17's much better.
Old Jan 23, 2008 | 04:30 PM
C4llyT's Avatar
C4llyT
Normal rattle can should last, all down to prep etc.
If you take your time, and have a decent surface for it to go onto etc.
I used a good amount of primer, pigment, then lacquer.
Once the lacquer is polished back, and you get and keep a layer or two of good
wheel sealant, should look like new for as long as you look after them, and keep them cleaned/sealed.
Keep them sealed and there's no need for aggressive or acidic cleaning methods,
simply shampoo will do.
This is rattle can finished
Gleaming in the sun after months of use
Halfords can aren't particularly good, unsure of a decent paint for the colour you require, but for lacquer Wurth is very good
Old Jan 23, 2008 | 04:33 PM
Dan's Avatar
Dan
I wouldnt do the backs on the lip/rim Phil, I had a small amount of paint on myu Old Style MO's and it affected the seal of the bead on the tyre and 1 out of the 4 wheels kept leaking air quite quickly, having now cleaned it off they are all fine!
Old Jan 24, 2008 | 12:08 PM
WD Pro's Avatar
WD Pro
I 'think' that mag corrodes from the inside if not protected, the first you will know is when it brakes Therfore I would paint / coat / protect all surfaces i.e. inside the tyre and beads to, better safe than sorry and all that shit
Old Jan 24, 2008 | 01:48 PM
Twellsie's Avatar
Twellsie
magnessium much like Aluminium forms a rapidly oxidiseing layer which in turn can lead to degredation of the material, on Aircraft applications there are strict proceedures about treating after blasting to prevent this, another problem associated with Magnessium alloys is that it age hardens much quicker than alot of alloys meaning it becomes quite brittle and much reduces its servicable life
Old Jan 25, 2008 | 09:42 AM
xr-stu's Avatar
xr-stu
Default Re: WooHoo..new wheels arrived and a question!
spinners
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
