HELP!! Gearbox problem
Old Jan 13, 2008 | 02:14 AM
intelligentfool's Avatar
intelligentfool
Default HELP!! Gearbox problem
Hi, my names John and I’m new to the ford scene. It’s only the second ford I've owned.
I've recently bought a P reg mk 6/7 Escort Si 1.8 16v Zetec.
About 2 weeks ago I noticed after going 80mph+ for a while then coming to lights and pulling off again, there was a horrible noise. A sort of grinding/ knocking noise. It stopped after I hit 40 - 50mph and only seemed to happen when I was going slowly. After half an hour or so I wouldn’t hear it again until I went fast again. It happened a few times then stopped for a week or so until tonight.
I was going down the M1 came off the slip road, waited for lights to change and set off again. As I did the noise happened again and it was really difficult to change out of 3rd gear, I had to really yank it out. I went down the slip road back onto the M1 and after about a 2 miles it made a clattering noise and rev'd out as if it wasn't in gear. So I took it out of gear and put it back in 5th and it did the same. Now I don’t have a 5th gear. It goes in as it should but just rev’s and won’t engage, just like it’s in neutral.
Does anyone have an idea what would have caused this?
Also what would be the best gear box to replace this one with, assuming it’s had it completely?
Do I have to fit a 'box from another 1.8 Si 16v Zetec or would I be better off fitting one from a different model? i.e. Mondeo, Sierra, Orion.
If I can fit one from a different model ford will it matter if I fit a 'box from a diesel, are they the same?
What about fitting one from a bigger engine?
Would fitting a ‘box from a bigger engine make it more economical?
What choices do I have?
I would appreciate any help you guys could give me.
Thank you
John
Old Jan 13, 2008 | 08:49 AM
Moondust_crust's Avatar
Moondust_crust
ever thought it might be your clutch mate, seeing as you couldent get it out of gear? , does the clutch have a high bitting point?
Old Jan 13, 2008 | 11:38 AM
big mac's Avatar
big mac
Sounds like the box has lack of oil 2 me m8 and its chewed 5th does it drive in other gears?
Old Jan 14, 2008 | 12:33 AM
intelligentfool
Yeah it still drives in all other gears.
Will it be a case of finding another 1.8 16v zetec and using that gear box or can you mix and match engines and 'boxes?
Could someone please advise?
Old Jan 14, 2008 | 03:43 AM
intelligentfool
Basically I need to know what to ask for when I start ringing around this week.
"Hi, have you got a ..... for a 1.8i 16v zetec please?"
What do I replace the blank with? Just "a gearbox" or are there specific models I need to ask for?
Sorry to be a pain but the help is much apreciated.
*smiles sweetly*
Old Jan 14, 2008 | 05:53 AM
Moondust_crust
fit one from the same model mate ie mtx75
they are much better than the ib5 model found on erst's and the like.
thats only if your sure its the gearbox, might as well put a new clutch in at the same time.
TPM961
Jan 15, 2018 10:50 AM
Flateric_2002
Sep 15, 2015 08:41 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
gingeRS
Sep 4, 2015 06:29 PM
