2wd saff missing problem
Old Jan 8, 2008 | 02:30 PM
mikelomax's Avatar
mikelomax
MOUSE
Default 2wd saff missing problem
a friend of mine has a 2wd saff that is completely standard and has not been used for a while.
the problem is that it has a missfire after about 200 rpm. it seems to idle ok but then miss on one cylinder after a few thousand revs.
it seems to me like an injector down and not fueling enough but could it me something more serious like maybe a bent valve.
it doesnt smoke one bit either.
regards
mike
Old Jan 8, 2008 | 08:02 PM
Normaly when you have a cent valve the engine will miss fire when at idle and when reved it will feel as if the missfire has gone away. Try the simple things like spark plugs mate.
Old Jan 8, 2008 | 08:14 PM
KSA-Cossie's Avatar
KSA-Cossie
Spark plugs,leads,cap rotor arm etc .
James Porter
Oct 28, 2015 12:17 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Anutternutter
Aug 21, 2015 06:07 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
