Focus Wheel Bearing???
Never changed one before, its really crunching on the o/s front wheel.What is involved in chnging it DIY style.
the car is a 51 plate focus ghia.
Any help or advice would be great
Thanks
Thanks
the front wheel bearings are press fit easyest thing you can do is take the complete hub off and take to a local garage that can press it out and press the new one in.
soak the abs sensor in wd40 over night before you attempt to remove it though as they are pigs and around £100 from ford
GTR_STU
Aug 28, 2015 01:02 PM
