Help needed Audi A4 1.8T :( *updated*
Old Jan 1, 2008 | 08:39 PM
Oranoco's Avatar
Oranoco
Default Help needed Audi A4 1.8T :( *updated*
Had some trouble with the car a little while ago with it being down on power, overboosting like a pig and being crap on fuel. After no fault codes been found on Vagcom I resorted to looking at things the old fashioned way and found one very black spark plug. I changed the plugs and the N75 valve as I had been told these were problematic. This half cured things and teh car returned to running .8 bar and holding .6 but was still smoking like a chimmney. It was suggested I ran a heavy duty fuel system an dinjector cleaner through which I did and voila I was seeing 400 miles on a tank and the car was a lot smoother although still seemed down on power.
Tonight the sodding thing decided to start over boosting like a pig again and lurching like it's hit over boost in third at about .6bar.
In short I've now got the right fucking hump and am starting to wonder whether the Superchip may be the cause of some of the problems. Any help or suggestions would be really good as I have a car I can't boot which kind of defeats the point of trying to get a few more ponies from it.
Old Jan 1, 2008 | 08:45 PM
lardypants's Avatar
lardypants
a real comon thing on these is the engine temp sensor is it a pig hot starting?
although it could be unrelated to your brobs it could possibly contribute
Old Jan 1, 2008 | 08:49 PM
Oranoco's Avatar
Oranoco
Starts and runs good as gold mate. Just plays up like a woman on blob as soon as you start to squeeze the throttle.
The other night coming back from my Dad's I put my foot to the carpet in 4th doing about 70ish and the boost came up but the car had no power and didn't pick up, just felt like it was being held back
Old Jan 1, 2008 | 09:11 PM
lardypants's Avatar
lardypants
do a throttle setting reset procedure thingy cant remember how exactly tho look on th net
Old Jan 1, 2008 | 09:35 PM
Jonzy's Avatar
Jonzy
Have you checked all the hoses? The overbraided vac hoses perish really bad over time and just fall apart, the rest of the rubber hoses aint much better either.
Could be a fucked coilpack?
If the car is DBWS, TBA in vagcom is under engine > meas blocks > block 060 > switch to basic settings for 60 secs... or just pop the bonnet, open the drivers door and turn the ign on. TB will click and whine for a 15-20 secs.
Old Jan 1, 2008 | 09:39 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Do these have MAFs like TDIs as these commonly are a problem causing similar symptoms!!!
Old Jan 1, 2008 | 09:41 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Yes they do.
Old Jan 1, 2008 | 09:47 PM
Lee_R21Turbo
Yes they do.
Cheers Martin.....I reckon theres a good possibilty of it being this mate!!
Old Jan 1, 2008 | 09:59 PM
EIL132's Avatar
EIL132
AFMs are a big problem, amongst other things. Mine had went through 2 of them and that was a standard A3 quattro. Total buckets of shite as far as I'm concerned.
Old Jan 2, 2008 | 07:57 AM
Oranoco's Avatar
Oranoco
The MAF was investigated when the car played up the first time an nothing was found to be wrong.
All hoses checked and then double checked
Might try and swap the recirc valve back to the standard one to see if that makes any difference to things. (stabbing in the dark now).
Drove like a big bag of crap on my way to work this morning so I've now got the hump with it.
First thing to give us bother since we got it last March though I spose.
Old Jan 2, 2008 | 08:18 AM
Lee_R21Turbo
When you say they 'investigated' the MAF….what exactly did this entail because sometimes VAG com doesn't even detect faults with these - its just a case of replacing it then seeing if this makes a difference - definitely worth doing anyway if you haven't already just for peace of mind!!
Old Jan 2, 2008 | 09:49 AM
Jonzy's Avatar
Jonzy
Log engine block 002 in vagcom, check the g/s value against what it should be pulling, turbo dependant.
I still put money on being a coilpack about to shit itself.
Old Jan 2, 2008 | 10:04 AM
Oranoco's Avatar
Oranoco
Can a coil pack and MAF really cause the boost spike problems that I'm suffering?
Think I should have stuck to my Fords.
Will get price on MAF as already have price on coilpacks. Are patern packs ok or should I use gen VAG?
Old Jan 2, 2008 | 10:07 AM
SapphyMike's Avatar
SapphyMike
this sounds like the common problem in remapped VAG T engines.
We're trying to work on a cure on the Briskoda forum.
Old Jan 2, 2008 | 10:09 AM
Jonzy's Avatar
Jonzy
ECP do geniune bosch MAF's for 80 quid exchange, VAG/bosch is the same thing and is about 180 quid new.
I'm running the hitatchi bolt down coilpacks that ECP stock and haven't had one fail in 18 months, bosch VAG part lasted about 4 before dying. The hitatchi seem to be coil pack of choice though.
I've put 50k on my 1.8t since its been remapped, its @ 120k now. Apart from 1 MAF, 1 MAP and a set of original coil's dying @ 80k, its been perfect. The problems are usually down to the maintanece of the whole car than fault components.
Old Jan 2, 2008 | 10:11 AM
Oranoco's Avatar
Oranoco
£260 for the MAF from my local motorfactors
Anybody recomend a VAG specialist in or around Hertfordshire? Can't afford to get it sorted but I can even less afford to twat the engine
Martyn's Avatar
Martyn
Do you know what revision the coils are?
Old Jan 2, 2008 | 10:12 AM
SapphyMike's Avatar
SapphyMike
Steve,
you have PM
Old Jan 2, 2008 | 10:15 AM
Oranoco's Avatar
Oranoco
Thanks for teh PM I have food for thought so will have a tinker.
Car has always been maintained regardless of cost. If it needs something it gets it and it was serviced a few weeks before I got it and I serviced it again just before Christmas.
Old Jan 2, 2008 | 10:18 AM
Ryan's Avatar
Ryan
got the same problem with my chippped golf, drinks fuel.
get about 40-50 miles to £10 and thats sensible driving
Old Jan 2, 2008 | 10:20 AM
SapphyMike's Avatar
SapphyMike
sounds like a problem with the map.
i mapped my Octavia vRS and i get at least 90 miles to £10.
you have another pm steve.
Old Jan 2, 2008 | 10:21 AM
Jonzy's Avatar
Jonzy
I get about 50 miles to a tenner, 220 to the tank @ £45 a tank usually.
Thats city driving though, on a run i can get about 320 to a tank @ 60-70mph.
Old Jan 2, 2008 | 10:23 AM
SapphyMike's Avatar
SapphyMike
thats woeful!
Old Jan 2, 2008 | 10:24 AM
Jonzy's Avatar
Jonzy
Seems to be the norm for most tbh mate
Old Jan 2, 2008 | 10:25 AM
SapphyMike's Avatar
SapphyMike
We Skoda owners must just be lucky then, as lot of us get better than that!
Old Jan 2, 2008 | 10:29 AM
Jonzy's Avatar
Jonzy
Maybe you are, but after 120k of abuse and still going strong I doubt theres much wrong with my 25mpg lol
SapphyMike's Avatar
SapphyMike
perhaps not lol. i just prefer my 35mpg+ LOL
Old Jan 2, 2008 | 10:30 AM
Ryan's Avatar
Ryan
sappymike, it was chipped by Stu @ MSD.
Old Jan 2, 2008 | 10:32 AM
SapphyMike's Avatar
SapphyMike
Then i doubt it is a problem with the map LOL
must be a fault elsewhere, as your economy isnt great
Jonzy's Avatar
Jonzy
But what are we talking about here, motorway driving or sitting in traffic jams 4 hours a day?
Old Jan 2, 2008 | 10:36 AM
SapphyMike's Avatar
SapphyMike
you said you get 320 miles to a tank at 60-70 on a motorway - no mention of sitting in traffic jams.
i get in excess of 400 miles at 60-70 on a motorway.
Old Jan 4, 2008 | 03:57 PM
Oranoco's Avatar
Oranoco
Update
After spending a morning in Leighton Buzzard with a company called VAGtech I am happy to reprt their guys found a broken wire to the MAF which immediately improved things and shock horror the MAF does appear to be the cause of my problems. Sorting a new one wil have to wait until payday but at least the car can be driven weithout feeling like it's going to explode when I tickle the throttle
Very plesed the chip turned out to be problem free as most people just told me it was the chip before anything was even looked at.
Old Jan 4, 2008 | 04:23 PM
pani_k's Avatar
pani_k
PassionFORD Member
Old Jan 4, 2008 | 04:26 PM
kiddie's Avatar
kiddie
result glad its sorted,
was it expensve to get diagnosed
Old Jan 4, 2008 | 04:42 PM
Oranoco's Avatar
Oranoco
Well still need to sort a new MAF for it to sort it properly but I'm 100 times better off than I was this morning.
Cheap as chips to diagnose, they did it for free. No catches or anything can't fault them at all.
Old Jan 4, 2008 | 08:10 PM
Wazzzer's Avatar
Wazzzer
glad you've found out what it is Steve, I'll know where to start if I ever get probs like that on the Golf
Old Jan 9, 2008 | 10:49 AM
SapphyMike's Avatar
SapphyMike
Good stuff Steve
If only the MAF would appear on the fault code list
Old Jan 9, 2008 | 10:59 AM
Ryan's Avatar
Ryan
i think this might be the problem with my mrs car.
anyone got one they can send me to try
JoeyBoyden
Jan 4, 2024 02:36 PM
cos elle
Sep 1, 2015 06:48 PM
borboyous
Aug 22, 2015 11:17 AM
M K
Aug 12, 2015 06:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
