Removing Dump Valve????
Should I remove the Group A dump valve from my cossie. It is currently fitted to the cold side & I am running 14/24 psi switchable boost with a hybrid T3. If I remove it will it have any detrimental effects on the turbo life? Can i expect the car to be any more or less responsive??
Help much appreciated.
Andy
Andy
what switchable boost you using?
I keep thinking about taking mine off, but its my first turbo and my dream when I was 17 was that noise
, so i'll keep it on untill it ever annoys me
Got two cossies running stg3 and both have no dump valves. Both have hybrid's and have never given a problem. Best advice i can give you is to take it off and stick it in your shed for a couple of weeks and see how you go. There are lots of different opinions out there on this matter as im sure you will find out. Good luck.
Cheers for the answers Guys! It will be coming off
I bought the car with it fitted & never really liked the bloody noise but left it on because i thoought it may cause a problem removing it!
Andy
Andy
Fudgey
Sep 17, 2015 01:06 PM
Si B
Sep 12, 2015 06:49 AM
