Tuners and such like i need help
I have an xr2 fitted with a fiest turbo engine running efi,
It has got....
t3 cut down blades saab compressor housing
double lapped valve springs
ported polished head standard cam
escort bottom end lighted balanced (very well) with larger oil return
lightend fly wheel
running xr2 box for better 0-60 times as that is what i am in to
standard injectors 8 psi
166 bhp 154 torque
I want to know what injectors to use and who can get the best out of this car as it is only running a shite 165 bhp super chip so defo need re map and tune up. I would love to hit the 200 mark. Any help would be great.
Thanks peeps
Darren
It has got....
lightend fly wheel
166 bhp 154 torque
Thanks peeps
Darren
Originally Posted by darren and hayley
Great help there then
you want me yo fookin fit them over the net aswell
any reputable Ford tuner will do
Have founs beiges but was told tonight to run standard escort coz injectors
Would like to stay away from coz management and do a bit old school aswell.
Unless they are the late escort cos type you wont be able to cos the injectors work on different impedance. Also when i said about using injectors out of another car i didnt mean a Ford
Originally Posted by Cossie Sean
im sure he thinks everyone has to have cossie managment on a RST.
But if you want more power than std the best way to get reliable and matched power from your engine is with a decent management system that can be adjusted to suit the demands at the touch of a few buttons, FRST are not like that! So once you have modded it, put a bigger turbo on it, different injectors etc.. what chip you going to use?????? Just some industry std superchip that was designed for the "everyday" uses we all know aint that good. AND what happens if you have a bigger engine than std??? How the hell does the chip know
Sean, you make it sound like i have something against RST's with KE?
I work with many std RST's that haven't had loads of work done aswell.
Its just my opinion
Regards
Jano
PassionFords Creator
Jano_OddKidd,
701s will be fine up to around 210bhp and then require upgrading.
ST Esc Cos will also be fine but you will need them live mapped unless you happen to know someone who has already mapped the system with those injectors at your engine spec.
The best advice is to take it to a professional.....
(cant make recomendations due to trying very hard to be unbiased
Just plugging in a chip and changing the injectors is not always the best way.
Live mapping will ALWAYS make the car better, safer and fuel efficient !
Good Luck
Good Luck
Originally Posted by Stu @ M Developments
Jano_OddKidd,
BTW how much is it to live mapp FRST EFi EEC4 ?
