Norwegian trackday sapphire, small x-mas rollcage-update 23.12.11
hi, thought i would put up a project-thread on my 2wd sapphire, to get feedbacks, comments and maybe an advise or two.
i'm gonna try to take i all from the beginning when i bought the car 2 years ago, i got it cheap, mainly because a bad engine and some rust. on the good side the car was fitted with a lot of good parts, and i got a spare 200-engine.
this is how the car looked like when i got it:
at the time running greys, mountune chip, turbonetics e-50 and all the usuall stuff.
the engine had a low oil pressure, was ratteling badly and generally misbehaving. i could drive it with 0.7 bar boost, but as soon as i set the boost to 1 bar or more, the car would suddently start to fire only on 3 cylinders. the electrode of the spark plug was jammed in each time the problem occured. also, remember, the engine had som really bad rattles, this was the reason:
the problem was mainly on cyl 4 but there was marks on all other cylinders, i have NO IDEA what the previous owner has been up to.
well, the engine was stripped, all use-able parts was put to side and the rest was scrapped. i rebuild the engine with the rebored 200-block, mahle pistons, balanced bottom end ++. the turbo was also scrapped since all the blades on the exhaust-wheel was damaged. bought a new Presicion SC44 turbo and bolted the engine back together.
all this was during the fall/winter 2005/2006 and in the easter 2006 we started to rust-weld all the rust that was on the car. me and a mate worked about 12-16 hours a day in 10 days to get it all finished
this is just some of the rust!
wasn't finished putting the car back together before late august 2006, just drove it some months, took it to one trackday (no picture, sorry)
i drove the car just ONE day to much....took the car to work a cold morning, had the original wheels with studded nokian hakkapelitta tyres on (well, the studs had been torn out, the tyres were ment to be used on a trackday) came all the way to work and on the parking lot the ground was frozen. to much speed + ice + crappy tyres =
came sideways over the parking lot and straight into a solid building (the irony was that the building was owned by a tyre-company...
the "only" damage was to the wings, rear bumber and a broken mirror. nothing on the doors...
well, a good reason to respray the car!
fall/winter 06/07 some work was needed on the car
the car when to the bodyshop and came back all white, will come back to this one, once i found the pictures...
the colour is just plain base white, no diamond white here as i think it may look a little bit yellow og grey sometimes. base white is soo much purer and cleaner!
also, wanted a little more power now, so bd16+ cams and pectel t2. the cams required the pistons to be pocketed and the head to be machined to accept double valve spring. this ment that the engine had to be stripped again, i also got jenspeed to machine the block for 4 long-studs. jens
also machined the pistons and the head. since the head was already ported this wasn't needed now.
put the engine back together and timed up the cams
didn't have time/money to mount and map the pectel now so the engine was still run on the mountune chip and grey injectors
drove at about 6-7 trackdays during the summer, with the diff collapsing at the second trackday.
borrowed a spare 7" diff and axels from a mate, welded it properly
some trackday-pics
but the co-driver/mechanic didn't seem to matter
i think this one looks cool, didn't have the sideskirts mounted, one of the first trackdays
the white paint is falling off!!
at the last trackday, wich was a small almost private one, the 6-pad clutch went and stucked itself to the flywheel, it was almost welded stuck! got hold of a new 6-pad, got the flywheel skimmed and put it together only to find out that the syncro-ring on third gear had gone. got sick of the car and didn't see it for a month or so.
finally got some motivasion (?) back and decided that the car was goiing to be a proper trackday-toy.
so out with all the interior, bar the upper part of the dash. also remowed all sound-shit and cleaned it
next step was to weld in a proper rollcage, first we stripped the car and took of the doors for easy access
then the welding started
the cage is build after the regulations that are needed to get a licence. since the car is still goiing to be "road-legal" and have plates, i need this licence.
the cage was also welded to the a-pillar and b-pillar for extra security and stiffness.
a-pillar shown here
the cage was also linked to the front turrets
the car is just gonna have the cage, 2 bucket-seats with 4-point harness, upper part of dash, the needed gauges and aluminium or carbon plates on doors etc. all you need to have fun!
i'm also goiing to wire up a completly new wire-harness, with just what i need and nothing more.
so, what main things to be done this winter:
get the inside painted white
mount everything inside
new gaz golds
wire up a new harness
change syncro-rings on the t5
new 750cc injectors
maybe a big-brake thing up front
maybe strip the underside and paint it
so, there you have it, i will try to update as soon as anything gets done on the car.
will come back to you guys with the full spec of the car if anyone wants to know.
please comment, ask or just have a look
some trackday-pics
a-pillar shown here
new gaz golds
new 750cc injectors
thanks for the comments
also, forgot to mention that i've bought a hydraulic handbrake
i'm also goiing to modify my steering rack even more, so that the powerslide-angle will be bigger
cheers!
cheers!
cheers!
yeah, i was never in doubt about the color. also, white just screams motorsport!
JHS: det er jo nye regler ang bur i gatebiler nĺ, har ogsĺ diskutert dette med mitt lokale biltilsyn, og sĺ lenge bilen er lisensiert i en motorsportsgren og at buret ikke stenger noen nřdutganger, dvs ikke kryss i taket ved takluke og avskrudde dřrstevere pĺ vanlig vei
kommer til ĺ lisensiere den i drifting, der er jo nesten alt fritt, hehe
eneste jeg er "bekymret" over er břttestoler og 4-punkts belter, selv om det er FIA-godkjent...
Originally Posted by JHS
Originally Posted by JeroentjeRS
nice project you have there.
Well and the ice??..... i had the same in norway 2 years ago
But no prob. The car didnt had a scratch
only problem was that 1 day later the head cracked
Had to leave him there.
thanks for all the comments, guys!
ruudsengen: hehe, alldeles ikke, uber-gammel adresse til samboer. bilen stĺr heller ikke pĺ noen adresser tilknyttet meg eller min familie sĺ
it's safe!
thanks, cliff s1!
i'm hoping to pass 500 bhp with no serious problems, the car will be mapped on a dynapack, so when the dynapack says the engine got 500 bhp, it has!
there's soo many that hit 500 bhp in the dyno, and when you get the car on a rolling road later, with all the car'a ancilliaries such as exhaust, intercooler, pipes and so on, the engine drops to around 400-450 bhp.
it also shows up at drag-strips. several "500bhpextremecossies" gets their asses kicked by a good stage3 cossie....
i want a REAL 500 bhp car.
also, there's so much things i want for mye engine this year such as a new intake manifold and a new exhaust manifold. 500 should not be problem with these items to, but they cost soo much!
but hey, money is made to be used, aren't it??
found some pictures of it when it was painted.
first i rewelded the front bumber fasteners to get the front bumber totally alligned
off to the bodyshop then
and back from the bodyshop in clear white!
gonna start to sand down the floor and get it prepped for paint this week. was hoping to be totally finished with the "interior" on this side of new-year but....time will show
been in the workshop today, most on the floor has now been filled and sanded down, ready for paint. just need some welding done to the bulkhead and on the floor where the original plastic-covers was.
took a few pictures of the cage as well, enjoy
rearview!
also fitted the outer part of the battery master switch
this cosworth belongs to a friend of mine and is in for a full body-overhaul
another friends 944turbo is getting the engine rebuild't
rearview!
JeroentjeJeroentjeRS
RS
hello i saw this picture: http://img.photobucket.com/albums/v2...n/PICT1568.jpg
this was on the Dovrefjell? and you had to leave the car on Dombĺs Bil rigth?? i live in dombĺs and remember you sierra!
cheers!
RS
cheers!
Keep the good work up mines take me 2yrs +++ now and still in the garage in bits
thanks billy_RST, don't know if it's gonna be mental but...
thanks alan_s1, not going to do it the way you did on the decompression-sones, the plates i'm putting there is going to be sikaflexed and fastened with pop-rivets. the round plastic-thingys is going to be welded like yours.
as we all know the ford's have a bad habbit of start rusting where the plates meet and is welded on the car, was hoping to prevent this as to not weld the plates.
still can't decide if i should bin the central-locking or not, would be much easier with the cable-streching and all, but it's also very convinient(?) to have. any inputs on this guys?
all the wiring, fuel hoses and brake lines is going to the middle of the car, gonna try to gather it and hide it as much as possible...
olek I have taken all my Central locking out The rear doors wont be in use as the cage will be in the way and im guessing your having no back seats in there so they can stay locked
But i am keeping the Electric window
the electric windows on my front doors is staying in mine as well. the rears doesn't have it.
gonna have an extra look and think how the wiring is gonna be, but as things look know, the central locking has to go... all i need then is the switches in the doors for the orginal roof-light, so that my alarm would still work.
is yours going to be a trackday-car as well? any project-thread here?
as it has a Side Exit exhaust and is 4inch from the turbo
Yes there is a thead on here some where i have to keep stopping it due to money ect but atm im waiting on my m8 to paint the inside so that the cage can go in and i can then move on with the wiring ect (not looking falward to that
finaly got my new injectors today, siemens deks genesis 750cc
bought from usrallyteam.com , nice guys, fast shipping and great prices! recommended!
i'm hoping to get a trigger-ring for the crank-sensor in a week. can't wait to get it started up with the pectel
cheers guys!
cheers guys!
cheers guys!
cheers guys!
Also good move getting the Siemens injectors go got aset in mine only the 55lbp tho
