Traction prob
Old Oct 9, 2004 | 09:23 AM
Neil@carwise's Avatar
Neil@carwise
Default Traction prob
Hi folks,
For the first time in my life I am truly scared of my car!!
1000cc inj, T70 turbo, highly spec head, 2.6BAR of boost =
this is in a 2wd saff with 215\tyres.
rev limit set to 8600, at 7000rpm its pulling so hard in 4th I wimp out and shut the throttle as its broken traction passing a load of cars
Old Oct 9, 2004 | 09:28 AM
Ross Lavery's Avatar
Ross Lavery
Fookin hell, what a monster I like to go sideways by cars but a T70
Old Oct 9, 2004 | 09:36 AM
Neil@carwise
Default tra
Yes its just plain stupid, when I started building it I just wanted as much power (without nos) as I could get. sounded like a good idea at the time, but I have built something that just makes my legs tremble when I boot it. Makes me sound like a poof but I guess you need to be in it.
Old Oct 9, 2004 | 09:51 AM
Ross Lavery
Sounds nowt but to me mate
Old Oct 9, 2004 | 09:55 AM
Neil@carwise
Default n
Mate, your a feckin nutta, but I like your style
Old Oct 9, 2004 | 09:56 AM
Ross Lavery
I wish I had a pound for evertime someones said that All the best with it Neil
Old Oct 9, 2004 | 10:01 AM
Neil@carwise
Default r
Cheers Dude
Old Oct 9, 2004 | 10:03 AM
Matt's Avatar
Matt
fit wider tyres, if you can get 255's on a 3 door you can get them on a saph too i guess
Old Oct 9, 2004 | 10:08 AM
Neil@carwise
Default T
I am pretty sure on a saff there is not enough room under the arches, unless I am wrong (which is distinctly possible). Does anyone know a good combo on the rear??
Old Oct 9, 2004 | 10:11 AM
RS220Turbo's Avatar
RS220Turbo
keepin that beast on the road, is class.
Old Oct 9, 2004 | 10:18 AM
Matt's Avatar
Matt
get the grinder out then, i have but only run 235/40, easier to do on a 3 door as you can hide your grindings with the skirts
a proper adjustable rear beam is a must if its lower than std ride height (mines std height), you need the correct camber or its all over the place
no word of a lie mine used to light 5th gear up on std suspension, std wheels and shit tyres, that was peaking at just over 2 bar @ 3400rpm, now peaks at 2.6 bar and dont break traction from 3rd upwards unless its wet or im shift too aggressively
my suspension is still shit mind (koni's) so it can and will get better when i get the billies ive been promising myself for ages
oh and my rear tyres and continental sports
Old Oct 9, 2004 | 10:36 AM
Kev H's Avatar
Kev H
Neil, have you tried even a set of 225's on the rear, these fit on the rear no probs with ECOS rims but mabey the offset plays a part
Old Oct 9, 2004 | 10:50 AM
Matt's Avatar
Matt
oh aye offsets
mine are ET33 comp mo's
Old Oct 9, 2004 | 11:09 AM
pugo's Avatar
pugo
hello neil.....its neil here (who got the head off of damian and pistons from you)
how u doing fella???, i was going to give you a bell about some bits but i lost your number????
Pugo
Old Oct 9, 2004 | 11:20 AM
Phil's Avatar
Phil
Jeebus
Get a proper adjustable rear beam on it then Makes the handling spot on! Remember every time you boot it and it squats you don't have 215mm in contact with the road but more like 20mm with a standard beam
Old Oct 9, 2004 | 12:21 PM
saphycozzie-adz's Avatar
saphycozzie-adz
when does the t70 come on boost as there fookin hoooooooooge aint they?
sounds gr8 fun.
Old Oct 9, 2004 | 12:46 PM
Moose 130's Avatar
Moose 130
lets see some engine pics so we can see just how big this turbo is then!
Old Oct 9, 2004 | 03:34 PM
Neil@carwise
Default m
sounds gr8 fun.
comes on at 5000rpm, 5300rpm is 1BAR of boost, after that its hard to tell, it comes on stronger than Mike Tyson on steroids. All I can tell you so far is that I have capped the boost at 2.6BAR and have not been beyond 8000rpm (it will rev to 8600). I have a photo of the Turbo on the car but dont know how to post it. For those of you that said at trying to keep it on the road you are quite right it is WICKED mixed with EVIL av it.
Old Oct 9, 2004 | 04:02 PM
gus's Avatar
gus
Old Oct 9, 2004 | 04:07 PM
Daviet's Avatar
Daviet
so who built this engine mate?? was it you
just if you have knowlege of that surely u could sort yourself with bigger tyres or a bit arch rubing.
car sounds wicked tho
Old Oct 9, 2004 | 04:17 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
245s will go on a saff.
What exactly is the engine spec n who built this car then?
Old Oct 9, 2004 | 04:21 PM
pugo's Avatar
pugo
he would have built it as he dooooo like to play and if you ever buy any bits from him *BE WARNED*
you end up on the phone for about 2hrs each time shooting the shit about cossie's
Pugo
Old Oct 9, 2004 | 04:23 PM
Phil's Avatar
Phil
Jeebus
I had 235's on my last saph!
Old Oct 9, 2004 | 05:06 PM
Neil@carwise
Default g
Err I do not have any arch rubbing probs mate, never said I did. "TRACTION PROBLEM" as a title was just to generate a bit if interest to the people on the board. I was merely asking the question, what have people fitted??
and yes I did build it, along with a lot of others, I just dont advertise or post much so you wont have heard much, if anything of me.
And as for you Neil Hicks, good lad, nice to hear you got it finished and it made the power, sorry about all the fat chewing, just get a bit enthusiastic about Cossies.
Old Oct 9, 2004 | 06:04 PM
djskitzy's Avatar
djskitzy
Grip is 80% your choice of rubber. The softer the more grip you get. Did you say you had continentals on? They are quite long-lasting tyres, which tell you they are a harder compound. I like the Pirelli P zero-nero's for grip, but my pocket hates them! I found a good balancewith Falkens, as I'm not producing anywhere near the power you are, they suit me fine, but with that much power, you need the best, and the widest. I'd go for 255 p-zero-neros... But that's me, there's plenty of chioce, do yer research.
Did I start rambling there?
Old Oct 9, 2004 | 06:13 PM
ben_frst's Avatar
ben_frst
Default Re: m
sounds gr8 fun.
send pics to b20001177@msn.com and i'll get em up 4 ya
Old Oct 9, 2004 | 06:25 PM
Neil@carwise
Default fgt
I use Bridgestone SO3s I find them a good all rounder for the road. on track I have been using cut slicks, but that has been on my 911 turbo, and 928. I took the saff on track a few times but not for the last two years so I have not had a chance to really look at the handling (been concentrating on the engine). Thanks for the advice though I might try a set of Falkens, might suit the car.
oh and by the way on track means "Track Days" not trying to blag IMA racing driver.
Old Oct 9, 2004 | 06:27 PM
Rhys's Avatar
Rhys
GEt some pics up
Old Oct 9, 2004 | 07:03 PM
pugo's Avatar
pugo
no need to apoligise neil, most people i meet just tell me i have a mk6 cortina gt!!!
i feel the need to drive up and come out in this turbo nutter bastard with you hehehe
Pugo
Old Oct 9, 2004 | 07:24 PM
Neil@carwise
Default h
Pugo
anytime my freind
pics on the way, the car was at National Day on a trade stand though albeit not finished and with a Toe4 on for running in purposes.
Old Oct 9, 2004 | 07:27 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
sounds where you from mate, what you recon its putting out power-wise?
Old Oct 9, 2004 | 07:30 PM
rapidcossie's Avatar
rapidcossie
so whats the biggest size you can fit on the back of a lowered saf without cutting arches?
Old Oct 9, 2004 | 07:34 PM
Neil@carwise
Default rt
My garage is in York,
and as for power hhhhhhmmmmmmmmmmmm I know what this board is like so I would not like to speculate, remember its not PROVEN so I would have to say its quite a lot more than a standard one.
It is badged as a Carwise 600bhp plus spec. I would say its a shite site quicker than Karlos's though.
Old Oct 9, 2004 | 08:22 PM
Default Re: T
235/45/17 Dunlop DO1j/ Jaguar 10" Diff/ Zoo rear beam kit. This will give you grip.
What gearbox /Diff are you running, please dont say Standard or i will start laughing.
600bhp will also require a Tremec TKO gearbox or similar.
Old Oct 10, 2004 | 12:21 AM
djskitzy's Avatar
djskitzy
Default Re: T
...a jag diff, you say? from what jag? Whats the benefits?
You've got me interested.....
Old Oct 10, 2004 | 12:33 AM
Rhys's Avatar
Rhys
Default Re: T
Originally Posted by djskitzy
Whats the benefits?
The Benefits is that it wont blow on you the min u show it some proper power
Old Oct 10, 2004 | 08:35 PM
Neil@carwise
Default Re: T
Sorry for slow reply Rod, been away from pc. Thanks for rear end advice, a call to Zoo is in order methinks.
Just for the record in case anyone was wondering (I doubt anyone is that interested), the engine was built by Carwise UK (me). The most important part of extracting power though, was carried out by The great man Karl Norris i.e. the headwork. Carwise has had a lot of heads done in the past, admittedly only about 40% of them Cosworth (I also do quite a few Nissans, RX7 s etc) but I have never seen heads like the ones Karl turns out. They should be on show instead of hidden inside an engine bay, but that is where they do their job so well. The engine is strong and smooth and it revs like nothing I have ever driven. This is down to the head and map. Big Respect mate you have done another great job. Karl does heads for most of the big power cars you hear of (not sure about yours though Rod) but alas being companies they rarely say who does their head work. Carwise UK builds engines, set ups etc etc, but ALL MY HEADWORK IS CARRIED OUT BY KARL. Also some mapping probs that need an engine designers expertise. I just wanted to clear this up as I didnt want to try and kid anyone I ported the head because I did not. All Carwise heads are prepared by NMS PERIOD.
Thanks folks and sorry to bang on.
Old Oct 10, 2004 | 10:02 PM
Alg1k's Avatar
Alg1k
Glad your happy with the performance Neil
Karls cyl heads are a work of art as you say
Mine was the dogs shame to bolt it to the block but i suppose its the best place
but i took a few piccys before hand
Old Oct 10, 2004 | 10:17 PM
Karl's Avatar
Karl
Norris Motorsport
Good to hear she's up and running Neil!! Shall be seeing you soon for the final mapping!!
Old Oct 10, 2004 | 10:59 PM
CozzyBrom's Avatar
CozzyBrom
Default Re: T
cheers for the shout rod
we be happy to help mate
