found my boost problem,, i hope!!
the spring in the waste gate had been shortened so it was not square causing the valve to jam i stripped it down and could see the valve stem was all scored and is pretty worn, wobbles about in the guide.
bet your glad to have found the cause, i wondered what was up with it at brands, then somebody said you was having boost issue's.....and there was me thinking my little xr2 was actually quicker as i went past you for the second time
be flying again soon then
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
saph in dorset
Aug 14, 2015 10:10 AM
