Modifying my sapphire 4x4
Hello,
I'm from belgium and I've just rewarded myself with a original Sierra cosworth 4x4.
Now I want to modify it!!!!!!
What should I do first? I was thinking about a mongoose exhaust?
Somebody some other suggestions?
That's what I had in mind. I don't know really much about cars. Only what I see on the internet or in fast/performance ford! And that it isn't cheap!
What type of airfilter do you prefer? K&N?
Yes,
K&N would be a good! altough all aftermarket airfilters have good quality.
I use K&N on my cossie. Is it standard? if no you can make a power upgrade too! you can make a stage 1 chip on the standard injectors with no more fuel required. Would be good idea if you if you change the wastegate actuator for a -31 and then raise up the boost to
......... let's say, 1 bar(14.7psi) 18 psi maximun.
Paul
Paul
Thx! I'm gonna order a mongoose exhaust in a few weeks and a k&n airfilter. But I'll better take a bigger one, cus I want a little more power next year! Brakes come together with more power!
Yes you wont reget going stg3 IE Chip (form stu) Dark Greens 803's injectors 3 bar map sencor you can run the T3 on that set up but not sure how long it will last (should see 300/330bhp) best going for a T34 tho and a big intercooler (rs500 style)
should see a good 350bhp (maybe a little more
Stu's got a Ebay shop
http://cgi.ebay.co.uk/Distributor-ph...QQcmdZViewItem
Happy shopping
Happy shopping
Happy shopping
Happy shopping
Happy shopping
Happy shopping
(i was just covering my self tbh as i would'nt want him to do it and blow his T3 and blame me
Happy shopping
Happy shopping
DaBoy12s Yes but it was "ment" to have been "rebuilt" 10,000miles before i brought it
