Modifying my sapphire 4x4
Hello,
I'm from belgium and I've just rewarded myself with a original Sierra cosworth 4x4. Now I want to modify it!!!!!! What should I do first? I was thinking about a mongoose exhaust? Somebody some other suggestions? |
Hi!
nice reward mate! Basically, you have an ocean of mods in front of you :DD: A mongoose exhaust and a cone airfilter would be a good start! bearing in mind that it's totally standard! |
Cone airfilter
That's what I had in mind. I don't know really much about cars. Only what I see on the internet or in fast/performance ford! And that it isn't cheap!
What type of airfilter do you prefer? K&N? |
modifying my sapphire 4x4
Yes,
K&N would be a good! altough all aftermarket airfilters have good quality. I use K&N on my cossie. Is it standard? if no you can make a power upgrade too! you can make a stage 1 chip on the standard injectors with no more fuel required. Would be good idea if you if you change the wastegate actuator for a -31 and then raise up the boost to :DD: ......... let's say, 1 bar(14.7psi) 18 psi maximun. Paul |
Phone Stu at MSD and buy one of his stage 3 upgrades - you won't be disappointed!
As above straight to stage 3 MSD 's chips rock. :banana:
sapphire 4x4
first thing I would do is get some big brakes on the car 330mm or larger if budget can cope as every one over looks this should always be the first mod on a sapp 4x4
Thx! I'm gonna order a mongoose exhaust in a few weeks and a k&n airfilter. But I'll better take a bigger one, cus I want a little more power next year! Brakes come together with more power! :D
Yes you wont reget going stg3 IE Chip (form stu) Dark Greens 803's injectors 3 bar map sencor you can run the T3 on that set up but not sure how long it will last (should see 300/330bhp) best going for a T34 tho and a big intercooler (rs500 style) ;) should see a good 350bhp (maybe a little more ;) )
Stu's got a Ebay shop :top: http://cgi.ebay.co.uk/Distributor-ph...QQcmdZViewItem Happy shopping :DD: :cry: :top: |
how about he gets expeience drivng the 4x4 standard for abit??
and then when hes comfrtable the go stage 3?? |
DaBoy12s Yes but it was "ment" to have been "rebuilt" 10,000miles before i brought it :cry: :cry:
Big brakes before you do anything else ;) :top:
Luciano |
www.remapping.co.uk :top:
© 2024 MH Sub I, LLC dba Internet Brands
