amal valve 'switch' for 2 stage boost
ok, for a quick fix to enable the boost to be turned down, i've put a switch to the amal valve.
its a T34, car normally hold 22/23psi, when switched off it hold 15/16, if that...
am I doing anything wrong here or putting the engine life in jepordy?, or is this ok. I've spoke to a far few people who have done this and say its fine
PassionFords Creator
Depends if the chip file was ever mapped with 15psi at WOT and high revs...
may be rich, may be fine, but worse of all, it may be very lean, on a transitional area ogf the map somewhere between cruise and the top boost line the map was intended to be used with..
JK12
33
Apr 26, 2021 12:09 PM
