plasterers - gen needed
Old Nov 6, 2007 | 08:34 PM
alistairolsen's Avatar
alistairolsen
Default plasterers - gen needed
Im lookig to get my hallway plastered, so Ive stripped off the old embossed wallpaper. Beneath it is old, smooth, hard plaster, and then some obvious repairs with pink stuff that looks like multifinish, but it softens when you have the steam stripper over it?
Some of the boxes round beams have been done with MDF, any problems with skimming this? Does it need replaced with pasterboard?
Someone once told me never to replair plaster without skimming it, as the odds on it being flt are slim and itll never feather in properly?
It needs to be flat and smooth because the hall is lit with halogen downlighters and the walls are going white. Can a decent plasterer do this with a float, or do they use long boards or owt?
cheers
Old Nov 6, 2007 | 08:53 PM
Basky's Avatar
Basky
knock off the loose and then darby it back level with bonding compound
then a skim over
Old Nov 6, 2007 | 09:06 PM
Brookesy's Avatar
Brookesy
Default Re: plasterers - gen needed
cheers
Plaster won't stick to wood, can you not screw some plasterboard over them with some beading on the corners
Old Nov 6, 2007 | 09:15 PM
Basky's Avatar
Basky
plaster will go on mdf
do it with kitchen walls where the cupboards go all the time
JoeyBoyden
Jan 4, 2024 02:36 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
