is it enough 4x4 intercooler for st3(standart T3 turbo)?
Old Oct 31, 2007 | 02:20 PM
Yura's Avatar
Yura
Default is it enough 4x4 intercooler for st3(standart T3 turbo)?
I know that bigger is better but....
Thank you!
Old Oct 31, 2007 | 04:02 PM
Ridgey's Avatar
Ridgey
Yes i think so.
Used to run a 3dr with 4x4 cooler, 803s on t3 20psi, with no problems.
Old Oct 31, 2007 | 04:20 PM
s1robinb's Avatar
s1robinb
Im running stage 3 with a T34 Garratt turbo on a 4x4 intercooler.
Old Oct 31, 2007 | 07:58 PM
cossiegreg1's Avatar
cossiegreg1
im running the same as you. im 22psi what you running?
Old Oct 31, 2007 | 09:07 PM
Bullett's Avatar
Bullett
me three.but i have just bought an rs500 cooler
Old Oct 31, 2007 | 09:10 PM
s1robinb's Avatar
s1robinb
23 psi matey
Old Oct 31, 2007 | 10:22 PM
scoooby slayer's Avatar
scoooby slayer
as long as the intercooler is in good condition itl be fine. i know someone who ran 26 psi on one for 3 years and never had any probs.
Old Nov 1, 2007 | 11:05 AM
silky16v's Avatar
silky16v
Get on That!
Default Re: is it enough 4x4 intercooler for st3(standart T3 turbo)?
Thank you!
This is not always the case there is an optimum inlet temperature, over cooling the inlet charge will make the ecu have to put the fuel in to match thus making it bad on fuel.
the cooler the charge the more fuel it needs
Old Nov 1, 2007 | 12:40 PM
Yura's Avatar
Yura
Thank you!
bigger cooler - colder air - more oxygen - ecu give more fuel(act sensor) - engine give more power...
Old Nov 1, 2007 | 01:10 PM
silky16v's Avatar
silky16v
Get on That!
Thank you!
bigger cooler - more air - ecu get more fuel - more power....
Old Nov 2, 2007 | 07:55 AM
Yura's Avatar
Yura
Thank you!
some correction
where am I wrong?
Old Nov 2, 2007 | 08:37 AM
s1robinb's Avatar
s1robinb
Having a ACT Gauge is a must imho and will never run a car without one now!
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
frug
Aug 26, 2015 06:46 PM
IAN RS2k
Aug 18, 2015 07:51 PM
