cut at 20 psi , heellppppp !!!!
Old Oct 30, 2007 | 07:03 PM
sygjim's Avatar
sygjim
Default cut at 20 psi , heellppppp !!!!
Mates have some problems with cossies..
all have 400 injectors with one a T3, another hybrid t34 and another gt28rs with 044, rs500 intercooler, ......
the problem, they can't have more boost than 1.4 bar (20 psi)....
my friend had search and test various plugs, distributor caps, chips, ...
but when the distributor cap is hot, if he unplug the plug cable number 3 , he has some spark near the distributor
do you think that the problems are linked ?
any idea ???
Old Oct 30, 2007 | 11:22 PM
mechanic28's Avatar
mechanic28
dont think so fella u say the boost wont go above 1.4 bar?there is no misfire etc?
Old Oct 31, 2007 | 05:56 AM
sygjim's Avatar
sygjim
no, 3 differents car has the same problem....
the chip use has 28 psi max, i think that it's a ignition problem, ...
Old Oct 31, 2007 | 10:47 PM
mechanic28's Avatar
mechanic28
could be what plugs are u using and what gap u set them at?
Old Nov 2, 2007 | 10:51 PM
sygjim's Avatar
sygjim
bosch F3CS, 0.65 gap
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
cossirob
Sep 16, 2015 07:39 PM
