last few cossie bits
Turbo inlet silicone hose - £5
turbo outlet std hose - £5
2wd front wishbones, pair - £10
2wd inlet manifold - £30
turbo coolant pipe - £SOLD
alt bracket - £2
fuel rail - £5
engine mounts, pair - £5
k&n filter - £5
clear sapphire indicators, pair - £5
sapphire headlights, pair - £10
headlight washers, pair - £15
2wd downpipe - £15
2wd exhaust system minus backbox - £20
rear arb - £5
front arb - £10
2wd bonnet - £20
dump valve - £20
steering rack and rubber coupling - £20
front subframe - £10
2wd std map sensor - £20
pas pump - £10
pas resevoir - £5
postage available on most items, pics on request.
cheers les.
alt bracket - £2
fuel rail - £5
k&n filter - £5
2wd downpipe - £15
rear arb - £5
front arb - £10
2wd bonnet - £20
dump valve - £20
pas pump - £10
pas resevoir - £5
cheers les.
Originally Posted by les3002
fuel rail - £5
cheers les.
cheers les.
yes mate its les3002@hotmail.com, do you need them posting?
if so it will be £10 by royal mail.
cheers les.
cheers les.
http://farm3.static.flickr.com/2392/...3a930187_m.jpg
ive not seen any others to compare mate, can measure it if needed.
Originally Posted by LoOnIe!!
money heading your way tonight les mate. Yes need posting.
chuck in that filter too mate. If roosie don't want it. Will pay when i get in from work.
front arb - £10
cheers les.
front arb - £10
cheers les.
Oct 9, 2015 07:38 PM
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
