Focus Clocks
Old Oct 24, 2007 | 10:10 PM
MURV69's Avatar
MURV69
Default Focus Clocks
Hi all
Over the last few weeks I have noticed that when I turn on the ignition on my focus 1.8 zetec the needles all go to maximum for a few seconds and then go back to normal, I have been told this happens if the battery has been disconected but I have not disconected and took it out tonight it did it when I first turned on and I drove to the petrol station (about 2 mile drive) filled up turned ignition on & it did it again. Is this a common problem or is something about to break??
Any advice much appreciated
Simon
Old Oct 25, 2007 | 12:08 PM
Big AL's Avatar
Big AL
IIRC it shows your battery is on its way out
Old Oct 25, 2007 | 06:02 PM
Mutton's Avatar
Mutton
Simon,
The cluster will only sweep it's gauges if it has either had the Battery disconnected or has detected a low voltage condition. As Al says, looks like your battery is on it's last legs.
Old Oct 26, 2007 | 01:33 PM
MURV69's Avatar
MURV69
Default focus clocks
Hi
thanks for the replies, the car has been left the last few weeks or has very little use, I will check the battery it seems ok though I will give it a good run this weekend
Cheers again
Simon
TPM961
Jan 15, 2018 10:50 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
