which gearbox is best to use for a 24v sierra
Old Oct 21, 2007 | 07:14 PM
richie mk5's Avatar
richie mk5
Default which gearbox is best to use for a 24v sierra
i cant decide wether to use the type 9 gearbox or the mt75 gearbox. for my 24v cosworth sierra. i have a type 9 box out of a xr4x4 i striped for bits. thanks.
Old Oct 21, 2007 | 08:19 PM
steve87's Avatar
steve87
I had a 2wd sierra with the 24v cossy lump in it.
I found that the type9 just couldn't cope with the power i put 2 type 9 boxes in the car within a few months,
I then dexided to put a 2wd mt75 gearbox in instead as theese are meant to be a much stronger box. I only did about 200 miles in the car with the mt75 box in then the engine let go , so i dont know if the box was any stronger,
But i can say the gear ratios in the type 9 were a lot better than the mt75.
I'm sure the ratios on the 2wd boxes and the 4x4s are the same but i have been told the 4x4 type 9 like what you have, has stronger internals than a 2wd xr4i box.
so if you find this to be true i would definateley recommend the 4x4 type9.
Old Oct 23, 2007 | 08:03 PM
richie mk5's Avatar
richie mk5
think ill try tht type 9 whats the worse that can happen
TPM961
Jan 15, 2018 10:50 AM
Bransby
Sep 11, 2015 09:12 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Adam Graham
Sep 6, 2015 06:04 AM
gingeRS
Sep 4, 2015 06:29 PM
