RST Manifold conversion for T28 Series...Ebay ends Fri 7.15
Since fitting my new Tubular Manifold, I will soon be selling the original setup from my car, which consists of the following :-
1 x Standard Manifold converted to T28 Stud pattern (so will take anything from a standard 200SX turbo to a GT28 or some of the GT30's)
1 x Spacer (to make the Compressor Housing clear the Manifold runner)
1 x 5-bolt to 3" V-Band adaptor (this converts the 5-bolt T28 exhaust outlet from the turbo to a simple 3" V-band style fitting.
1 x 3" Downpipe (with EGT and M18 Lambda boss fitted, this downpipe would require modification of the exhaust system to join it. Mine had a 4-bolt flange in the exhaust under the steering rack, this is quite easy to sort. The downpipe is wrapped still, but the wrap is a little tatty now).
1 x Adapted Oil Drain (this will bolt straight onto the appropriate turbo and take the normal RST oil drain hose)
Would this litte lot be interesting to anyone?
Remember it is what has run on my car for the last couple of years and has produced 350bhp.
Incidentally, as you can see from the picture, it clears the Alternator, but with the original heatshield, so the downpipe will certainly need to be wrapped. As I said, it is wrapped now, but might want re-wrapping if you are as fussy as me!!
Now on Ebay due to being let down by the original 'buyer'.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE:IT&ih=006
It would just make a cheap alternative approach for someone. As I said in the auction, you can pick up a T28 for reasonable money and they are a very good turbo.
Ive been using one for 5 years
Originally Posted by Billy_RST
So i could use the 'Disco Potato T28?'
This auction finishes at 7.15pm on Friday! Get bidding!!
JK12
33
Apr 26, 2021 12:09 PM
liamT74
Sep 23, 2015 10:24 PM
