Turbo help needed
Old Oct 13, 2007 | 03:01 PM
Phyco's Avatar
Phyco
Default Turbo help needed
can anyone tell me. if i was to take my turbo exhaust housing off would the turbo need to be re ballanced or can i just bolt the housing back on and refit the trubo. god i hate cars.
all i wanted to do was put a new exhaust manifold gasket on and refit a stud and a small object fell into the manifold and dropped down into the turbo. so anoying.
Old Oct 13, 2007 | 04:27 PM
jon@work's Avatar
jon@work
it'll be fine - won't need re-balancing
Old Oct 17, 2007 | 02:31 PM
SafeChav's Avatar
SafeChav
As above it'll be fine - HOWEVER that can be a PROPER cunt of a job!
One turbo i did i had to grind 4 of the bolt heads off because they were seized solid and then rounded off.
And even then i had to SMASH the housing off with a lump hammer........and if it doesn't come off square theres a chance you might damage the fins on the turbine.
If it comes off easy then its a straight forward job though
Old Oct 17, 2007 | 08:09 PM
MarkN's Avatar
MarkN
You should be a precision engineer mate with your lump hammer. Have you ever thought of making watches?
Old Oct 18, 2007 | 01:49 PM
SafeChav's Avatar
SafeChav
What else can you do if its seized on there
Thats what hammers are made for! i did have pictures of it all but cheap DVD-R's mean they are no more
Old Oct 18, 2007 | 08:09 PM
MarkN's Avatar
MarkN
Yee haw cowboy!
Old Oct 19, 2007 | 10:19 AM
SafeChav's Avatar
SafeChav
so how else would you remove a housing if its seized on.
Can't wait to hear this one
Old Oct 19, 2007 | 03:33 PM
Moonie's Avatar
Moonie
I have got them off in the past by heating the nuts up and getting a good fitting 6 sided socket.
Old Oct 19, 2007 | 09:59 PM
SafeChav's Avatar
SafeChav
i mean the housing not the bolts.
And you can't get a socket in on the exhuast housing bolts or at least not all of them
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
