3 door cosworth ECU loom to car loom
Hi lads con you help please when i bort my car it was a track car which im putting back on the road and it has had the loom cut up very bad so i have bort a new one but iv had a look tonight and i can not find the ECU plug on it so this is were i need your help i think my old loom might be out of a saf as the fus box will not fit were it should go i have some photos here of wot i now the wight plugs are on my old loom ?.i think the black plugs on the new loom are the ones for the ECU but not 100`/. if the old loom is a saf do i need to get a 3 door ECU loom or wot and are the black plugs the right wones PLEASE HELP
SORRY THE PHOTOS ARE NOT THAT CLEAR I WILL HAVE A NUVER GO
the black plug on the left of the top pic is the engine loom plug
the black plug on the right of the top pic may be for the tweeter in the side of the dash
I don't think the white plugs are standard
JoeyBoyden
Jan 4, 2024 02:36 PM
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 14, 2015 07:29 AM
