SURGE
Old Oct 3, 2007 | 07:43 PM
Twellsie's Avatar
Twellsie
Default SURGE
The way i understand it, surge is when the turbo produces more air than the engine can consume?
is this right?
also i have heard that some turbos are more prone to surge than others, if this is true, why?
Old Oct 3, 2007 | 07:47 PM
lead_foot's Avatar
lead_foot
is awesome
Default Re: SURGE
is this right?
Yes, as far as i'm aware.
I wouldn't think any turbo is more prone to surge than any other. The turbo surges if its incorrectly spec'ed for the engine.
GARETH T's Avatar
GARETH T
yes, being very basic
yes and some turbos are more susceptible to surging, due to there design,, normally a too small of exhaust housing compared to the compressor
Old Oct 3, 2007 | 07:53 PM
Twellsie's Avatar
Twellsie
ahhh, i can now see the picture in my head...
turbo produces so much pressure (as the engine cannot consume more) and the exiting exhaust gasses do not have enough force to spin the turbo?
Mark Shead's Avatar
Mark Shead
This only happens mainly on the smaller turbos mainly GT3071 or below, The Larger units like a GT35 can run the .63 without a problem, Surge on these is down to airflow.
Mark
Old Oct 3, 2007 | 07:54 PM
lead_foot's Avatar
lead_foot
is awesome
Ah, that makes sense. It will have a lower boost theshold with a smaller exhaust housing?
Old Oct 3, 2007 | 08:05 PM
scoooby slayer's Avatar
scoooby slayer
my car was surging very badly when i got it. its a t4 to stop surge boost was caped to 22 then 26 psi below 5400 rpm then after that it runs 32 to the limiter and loves it. the surge was so bad before set up it was jumping up and down about 8 psi on the gauge
Old Oct 3, 2007 | 08:19 PM
GARETH T's Avatar
GARETH T
change the word pressure for flow, and ill be happy
Old Oct 3, 2007 | 08:32 PM
Twellsie's Avatar
Twellsie
but as the engine cannot consume it, its not flowing? therefore pressure?
Old Oct 3, 2007 | 08:40 PM
GARETH T's Avatar
GARETH T
turbos produce flow,, pressure is force acting on an area! so therefor the engines isnt consuming the flow
Old Oct 3, 2007 | 10:15 PM
Twellsie's Avatar
Twellsie
sorry Gareth you clearly know what you are talking about, unfortunately the turbos i work with are a bit bigger and the terminology doesn't quite read across, but i think i get where you are coming from buddy
Old Oct 3, 2007 | 10:36 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Surge line is one the left:
If you dont know how to read a compressor map, look here:
http://www.vauxhall-sport-forum.com/...urbos-t92.html
Old Oct 3, 2007 | 10:42 PM
Twellsie's Avatar
Twellsie
sorry Chip, do you a plot for a BR710, RB211 or T1000, as i dont know much about the one you posted
Old Oct 4, 2007 | 06:13 AM
Surge is NOT as described but when the COMPRESSOR side cannot produce ENOUGH airflow, due to bad ratio between TURBINE and COMPRESSOR sizes.
The surge effect is caused by the air speed stalling due to not having enough power transmitted through shaft to drive it sufficiently hard, due to amongst other things too large a compressor side unable to build boost, which is continually being used.
All turbo's have a window or engine load/rpm where they operate best, below this pointy you can get a surge situation whereby the flow is unstable due to the turbo not being able to supply enough air.
When the mass flow rate through a compressor is reduced while maintaining a constant pressure ratio a point is reached where local flow reversal occurs in the boundary layers, if the flow point is further reduced complete flow reversal occurs.
This will relieve the adverse pressure gradient until a new flow regime is established at a lower pressure ratio, the flow will then build up again to the initial condition and this flow instability will continue at a fixed frequency and can be quite violent and is called surge.
It is more prone on turbo's that have a small operating window.
Put simply there are various reason for surge but most common is bad match of comp/turbine housing sizes whereby the shaft connecting the two cannot transmit enough force through to the compressor side due to compressor being to large, and power transmit not being great enough from turbine impeller.
BRAM
Sep 8, 2015 07:11 AM
JTECH James
45
May 13, 2007 02:45 PM
EricYellow
Jul 2, 2006 11:36 AM
Stavros
25
Jan 20, 2006 09:05 PM
CossieRich
Jul 15, 2004 09:50 AM
