I LOVE The Parts Man At Ford!!
Old Oct 3, 2007 | 09:48 AM
BillyCabrio's Avatar
BillyCabrio
Default I LOVE The Parts Man At Ford!!
MAJOR PHEW!!!
While re-fitting my head last night () I had to remove and then refit the oil return pipe for the turbo as it had moved round when the head was taken off.
I gave the pipe a quick glance over and noticed that the jubilee clip had slowly been working its way thru the outter skins And this is a Roose Motorsport hose It had also spit on the inside, looks like its on the last skin holding it together.
Typically this had to happen as nothing runs smoothly lol, the rest of the car was put back together with this being left until this morning to sort.
I rang Paul @ Roose and explained what had happened, now for some reason they don't keep these pipes on the shelf and i need one by tomorrow latest!! But he cannot make me one up until tomorrow but promises me it would be with me on Friday sometime, great but not so great.
I thought i'd risk it and try my mate at my local Fords, now i know these can be quite expensive and rare from Fords but its a matter of needs be as she's booked to have some electrical work done today which involves the engine needing to be run and into TOTD for tomorrow afternoon and then the Pf RR day on Sat.
Now this fella i know is a fooking dude and for some unknown reason rolls finis codes off like he's saying the alphabet, you ask something 9 times outta 10 he knows the finis code off of the top of his head
He did a quick search but no local Fords were showing one, he traced one down in Tunbridge Wells and is getting it TO me for 13.30!! At trade cost
£35 all in to be exact And the Roose one is £27, so not to much of a difference.
So i can bung that on until the Roose one arrives, at least it'll get me thru the set-up and the RR day!!
Phew..............
Right i better crack on with all the other little bits.........
Old Oct 3, 2007 | 09:54 AM
foreigneRS's Avatar
foreigneRS
Testing the future
nice one
one thing though - he's the man at ford, not the man at fords
Old Oct 3, 2007 | 10:04 AM
BillyCabrio
Sorry lol
God its like having Dave Mulheran back
Old Oct 3, 2007 | 10:11 AM
foreigneRS's Avatar
foreigneRS
Testing the future
it's just one of those little things that i find far more annoying than it should be
thanks for comparing me to the great dave mulheran - i now feel like a god
Old Oct 3, 2007 | 10:26 AM
ballin's Avatar
ballin
Why swap it to the Roose one when it arrives, I would rather have the Ford hose on there?
Old Oct 3, 2007 | 11:21 AM
GUZZLER's Avatar
GUZZLER
dont use jubilie clips on it either, use the proper spring clips
Old Oct 3, 2007 | 01:00 PM
BillyCabrio
Spring clips?
Old Oct 3, 2007 | 01:33 PM
dojj's Avatar
dojj
Resident Wrestling Legend
clips that spring
you use pliers to fit them and they hurt like a mother if they slip and twang your fingers
Old Oct 3, 2007 | 04:05 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Originally Posted by dojj
clips that spring
then stop being pikey and get proper spring clip plyers
paul its whats MENT to be fitted to em when there on there, there metal on the return, there a smaller version of the plastic hose clips as fitted to you missus old fiesta 1.25 ect on the water pipes to the rad ect
listen to matt, he knows what hes talking about
Old Oct 3, 2007 | 04:10 PM
Paddy's Avatar
Paddy
Legend
What they said
You tight gypsy cunt!
Your guy at Ford sounds like rainman and you should make him aware of this.
Old Oct 3, 2007 | 06:41 PM
dojj's Avatar
dojj
Old Oct 3, 2007 | 10:28 PM
Ginge !'s Avatar
Ginge !
any old microfiche parts man will know part numbers for things like sierra rear lamps, or serivce parts as its a arse to find stuff on them you will remember
the partsman in my old branch is nicknamed " the oracle" as he knows part numbers, locations, parts that are similer that would fit, rivet sizes, reasons why forks on gearboxes dont fit blah blah blah
the man knows EVERYTHING, hes such a quiet bloke too
one day i was bored at work and so i went to the microfiche, turned it on and grabbed a slide and swung it about,,, gave him a part number and he was to tell me what it is
HOW THE FUCK ANYONE KNOWS THE PART NUMBER FOR A DOOR MOULDING ON A MK4 CORTINA ILL NEVER KNOW,,,,, HE EVEN KNEW THE FUCKING SIDE OF THE CAR IT WAS TO FIT
i tried to learn part numbers and remembered easy ones like 1066071 for focus oil filters and 1060606 i think for mk6 escort top gearbox mounts
BUT ITS CAUSE I SOLD 10 OF THEM A WEEK
same with the heater valves for fiestas and heater resistors for mondeos/focus's
but the oracle,,, i STILL call him up for info and i dont work there anymore
Old Oct 3, 2007 | 11:20 PM
©hatter Box's Avatar
©hatter Box
ditto then you would not be in the shit
Old Oct 3, 2007 | 11:21 PM
BillyCabrio
Text or PM me the finis codes then mate
Old Oct 3, 2007 | 11:22 PM
Ginge !'s Avatar
Ginge !
alex is a e-cat boy,,, he needs hes tft to get codes
Old Oct 3, 2007 | 11:25 PM
©hatter Box
thats where you learn the part numbers when your on the back counter i been on it for the past 3 weeks and boy your learn numbers fast for pre pick services
Old Oct 3, 2007 | 11:35 PM
Ginge !'s Avatar
Ginge !
alex you forget them just as quick
i dont even remember the fucking part number for butyl tape or even a fucking fiesta pollen filter,,,,, and fuck me i done LOADS of them
i know thesumo plug ends 372 i think or someing like that
Old Oct 3, 2007 | 11:37 PM
Ginge !'s Avatar
Ginge !
btw,,,, back counter is where they stick the trainees before they work on front counter,,,, then the phone office
the way your going in 6 months you will be doing the M25 van run
Old Oct 3, 2007 | 11:45 PM
©hatter Box
ecat used it once still got micoat thank you
Old Oct 3, 2007 | 11:48 PM
©hatter Box
i been on the phone for the last year and i am bored it full of back st garages not knowing Shit and want to know how to fit the parts 24/7 van run mmmm sound good
Old Oct 3, 2007 | 11:50 PM
©hatter Box
5052296 escort mk4 headlight covers 5052299 saff covers 5052355 rs soft spokes need i go on
Old Oct 4, 2007 | 12:01 AM
Ginge !'s Avatar
Ginge !
alex you think you had it bad,,,,,,, i sell pattern parts to back street garages but i have to deal with the factors who order them for the garages and no cunt speaks a word of english
its me who has to work out why it dont fucking fit then send them something that will work
trust me its not easy when you are working with PROPER cowboys and people who order parts for cars not even knowing how to tell if its 8v or 16v
i ALSO have to deal with the problems from quickfit as we supply them fucking exhausts,,,,, they dont even listen to a fucking word you say,,, they just wait for a gap in conversation and reply with anything they can think of
example
me: mate is it a 8v or 16v engine
dumb fuck kwick fit cunt: yes its a renualt clio 3 door
ME: thats nice,, is it 8v or 16v
cunt: its a petrol
me: mate,, IT IS A 8 VALVE ENGINE OR A 16VALE FUCKING ENGINE
cunt: the registration is LD53LZD
ME; mate can you hear any fucking thing im telling you
cunt: its a renault clio on a 52 plate,,, the exhaust is not fitting can i have the right one please and stop wasting my time, im a busy man
ME: CAN________ YOU________ TELLLLLL ________ ME_______ HOW_)____ MANY______ VALVES___________
cunt: im sorry,,,, i cant tell you how many valves as the car is in the air,, i just need a exhaust that fits,,, how hard can it be, just send me one
me: MATE WE HAVE<<<<<< THIS IS WHY I AM TALKING TO YOU AS TH ONE WE SENT IS WRONG
cunt: yes just send me a exhaust, for a renault clio,, hold on ill get the manager,,,,,
manager: i need a exhaust for a renult megane scenic,,,
me: WTF,,,,, what car are you working on
manager: its deffo a renault,,,, or some sort,, just send me a exhaust and stop bothering us,,,,, we have things to do here
me: can i speak to someone there that is not working there with a green card please,,,,, i need a person who can understand english aswell as speak the fucking language,,,,,, i go home at 5 and i wanna see my child grow up
manager: i dont like you tone,, i wanna speak to you manager
ME:,,,,,,,,,, transfering you now,,,,,,, BYEEEEEEEEEEEEEEEEEEEEEE
then i get the next call like that
Old Oct 4, 2007 | 12:03 AM
Ginge !'s Avatar
Ginge !
how about items you actually sell at work for customers and NOT ON FUCKING EBAY TO PAY YOUR MORGAGE
Old Oct 4, 2007 | 12:07 AM
©hatter Box
you have a good day then better then fords
i know what you mean if they like that over the phone what they like fitting the parts
Old Oct 4, 2007 | 12:09 AM
©hatter Box
i know all efi500 efl 600 efl 10 and the papers oil fillters have all changed parts numbers 1066071 efl 600 to now diff
Old Oct 4, 2007 | 12:14 AM
Ginge !'s Avatar
Ginge !
mate ive had some PROPER worrying things,,,,,, guy doing BRAKES asking me if the cars got ABS or how can he tell
people asking for LOCATIONS of parts,,,, fitting clutches to galaxys and not knowing what a dual mass flywheel fucking is
and mechanics who wont check because either the car is outside or its in the fucking air,,,,,, instead they want me to send out all the options and he will send back what he dont use
tbh im lucky as im not on commision like others and im not sales targeted ect due to my other things i do in my job
theres one guy at my work who if he asks 3 questionsn and hes not got a decent reply by 50 seconds he cuts the call off and takes another call leaving someone else to deal with the african dream
mind i DO have to take 150 calls per day and have a reason WHY i couldnt resolve the issue,,,,, and saying "the blokes a cock" only works for every other email to the customer services manager
Old Oct 4, 2007 | 12:23 AM
Ginge !'s Avatar
Ginge !
oh i forgot to mention ive been told off alot for replying to confused mechanics who answer me in a strange tone
" are you sure,,,, you aint lying to uncle ginge are you,,,,,,, go on sweetie,,,,, this time actually OPEN the bonnet,,,, check the actual part and tell me if its fuel injected or has a carb fitted to it "
oh and the WORST bloke i had was a land rover,,,,, the bloke wasnt sure if it was a DIESEL OR FUCKING PETROL
i asked him to check,,,,, he says "oh ok" and it goes quiet for about 10 mins,,,, then i hear him cough so i ask "pal,,, you still there",,,,,, he replys yeah
so i ask, "well diesel or petrol"
hes reply,,,,, "OH YOU WANT ME TO GO AND CHECK"
NO MATE,,,,, I MENT IM GONNA DRIVE TO FUCKING BEDFORD AND OPEN THE BONNET OF THE CAR 10 FEET INFRONT OF YOU THEN DRIVE BACK TO LONDON AND TELL YOU ITS FUCKING DIESEL
seriously i had that happen,,,,, the bloke ACTUALLY though i ment I was gonna check for him hence HIM holding for me
he couldnt tell me how i was gonna tell him but he thought i was gonna check and tell him
Old Oct 4, 2007 | 12:24 AM
©hatter Box
african dream i am starting to feel sorry for you in your job
Old Oct 4, 2007 | 12:29 AM
Ginge !'s Avatar
Ginge !
alex a year plus bonus ( when i fucking get it ) for a bloke who 2 years ago was working at halfords PART TIME ON 7k a year in a job when i check peoples mistakes and the only downside is the fucking morons who we sell the shite to
dont worry about me that much as ive never been so flush and not had to worry about people hating and grassing me up
its not the same as working for fords though,,, i cant take the piss as much and i do actually have work to do but i get almost 8k a year more and i dont work in stamford hill
Old Oct 4, 2007 | 01:06 AM
SS1's Avatar
SS1
Ginge !
i guess what i found on the net
New genuine rear lamp gaskets Ford Sapphire Cosworth
near enough deleted item from ford now. ive been waiting for 3 months for ford to find them. there order went out of the country WTF
CARNT FIND THEM FOR LOVE NOR MONEY
mine all mine
paid £16 for the foam inserts too
ford price was £18
Botts
Aug 13, 2015 04:16 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
