st24 running problem
Old Sep 28, 2007 | 01:31 AM
combi van man's Avatar
combi van man
Default st24 running problem
i brought this car about a month ago n drove it 4 three days it drove fine when i got it & now it keeps blowing these 2 pipes of on the recirclator from the exhaust manifold(back 1) & it then loses power & makes a hummin noise from the air box.does any1 know the problem with it??????????
Old Sep 28, 2007 | 05:50 AM
Piccies, is it the EGR pipes to which you refer ?
Old Sep 28, 2007 | 09:57 AM
combi van man
yes it is the EGR pipes.couldnt remember wot they was could at the time.can you help me cause if cant sort it out im goin to sell it as need a car that works?
Old Sep 28, 2007 | 12:38 PM
Are you sure it's egr and not a PULSE air system ?
Either way you can remove it all anyway, but must leave PRESSURE DIFFERENTIAL SENSOR PLUGGED IN or it could go into LOS.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
