best relay
whats the best relay and cable to use when re wiring the cossie fuel pump, can i use a pink ford fuel relay (rst/xr3i) as i have a few of them about ?
i have just been asking all this as i am fitting a group A pump and thinking bout rewiring her
click on this link
http://www.vehicle-wiring-products.e...e/homepage.php
i am thinkin of going with a 30 amp relay type b the ref number is r20b
but i suppose the relay u said is all ok
click on this link
Originally Posted by KSA-Cossie
I used 10mm cable and a 40a rated relay,i ran a positive and a negative.
cool i am going to use a 15/20amp fuse on the feed from the battery run it down the original course of the wiring bring the new wire up to where the cut of switch is and locate new relay there,then cut the wires coming from the cut off switch to the pump and use them as my trigger for the new relay(so it keeps the cut of switch in the loom for safety reasons!)then run the new feed down to the pump following original wiring then feed a new earth agian following original wiring all the way to the battery
i used a 40 amp 4 pin relay and 35 amp wire got it all from maplins
i ran 1 live and 2 earths from battery to spare wheel well
used the original fuel pump live as trigger to relay, new live to relay and new earth
then from relay new live to pump and the other earth from battery to pump
works spot on
works spot on
works spot on
works spot on
coswurv
heres a link to my resto where you can see whats involved and how it looks
https://passionford.com/forum/viewto...180&highlight=
i carnt remember where abouts it is but somewhere on pg2 id imagine
cables arnt that thick they dont need to be
here you go mate this is how ive done mine, i think i got th pins correct but will have to double check as carnt remember at the mo
reason i didnt use my interia switch is becuase i plan to run a stero in te boot and the bass used to knock my switch in my old xr lol
but if alls you need to do is put inline with the new live going from relay to pump
the cut off switch uses the live for the pump not the earth
so you need to put this to the new relay
then from the relay the new wire for the live you have to put the inertia switch in
thats how i would do it
but you may be able to keep the original wiring and just take the original live to the new relay
You will build no resistance that is going to make shits worth of difference at this level by earthing at the battery, it's complete crap, but is banded about often.
Use the formula,
R= pL/A to determine resistance, if you want to be fussy.
Copper wire has a resistance of 0.000999 ohms foot@10 Gauge and 20Degress Celsius.
Use the formula,
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
