ST170 Engine & Series 3 Zetec Cams
Old Sep 21, 2007 | 07:10 PM
CCassidy's Avatar
CCassidy
Default ST170 Engine & Series 3 Zetec Cams
I'm looking into using an ST170 engine, basically, cause it's got better headwork, conrods etc
Now all the variable stuff will be binned, and I'll be using my WeberAlpha throttle bodies & management.
Now, I want to know if normal S3 zetec cams will physically bolt into the bare ST170 head, as I can't use my current S1 Zetec cams in it, and would also like to go to something a little bigger than what I'm currently using.
Old Sep 22, 2007 | 01:26 PM
inis's Avatar
inis
have to get a reg zetec head. Your exhaust cam wont bolt in either? I know the intake wont, but I'm curious if the exhaust will...
Old Sep 23, 2007 | 07:29 PM
CCassidy's Avatar
CCassidy
Cheers for the reply mate
Do you know exactly why the inlet cam won't fit?
Old Sep 29, 2007 | 09:22 PM
Wardy257's Avatar
Wardy257
Why are you binning the VCT? Never heard anything good about webber alpha either.
Old Oct 1, 2007 | 10:57 AM
AustenW's Avatar
AustenW
inlet cam has a larger journal size
Dont touch webber alpha either
Old Oct 2, 2007 | 10:21 PM
pdfbt40's Avatar
pdfbt40
Not only does the inlet cam have one larger journal size (the first one), but it is also slightly displaced longitudinally. The exhaust cam has the same journals, but..........
Both cam profiles are matched to the different valve stem length and solid cam followers, so the base radius is also different to standard Series 3 (Blacktop) cams.
Don't know what the spec is but Piper do reprofiled ST170 cams. Also Ian Howell has developed specification for ported ST170 head, valves and cams.
Martin
JoeyBoyden
Jan 4, 2024 02:36 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Roosie
Aug 13, 2015 07:40 PM
