Door Card Removal
Old Sep 14, 2007 | 12:48 AM
DeanO Xr3 CoV's Avatar
DeanO Xr3 CoV
reppin' passionford hard!
Default Door Card Removal
I know this probably doesn't deserve to be in the technocal section but hey ho can you advise me on this. My rear windey window doesn't work on my mk5 escort (not my xr3i) so today i thought i would try woop off the door card to inspect it. Sadly, after unscrewing all the errr well screws!,,, the door card will still not come off. It seems all that is holding it on is the window winder itself which appears to be stuck fast. It doesn't rotate what-so-ever and i'm unsure of how to remove it! HELP!
Old Sep 14, 2007 | 12:52 AM
DeanO Xr3 CoV
P.S. The winder itself is all one moulded piece of plastic so i cant seem to pop off any cap cover to unbolt it etc
Old Sep 14, 2007 | 12:58 AM
jawanne's Avatar
jawanne
hi there is a clip behind the winder and make sure that you have took all the screws from the ends of the door card and then once the winder is off you just pull the the door card off as it will be only helled on by the the pastick clips behind the card its a easy job mate but if water has got behind the winder in the door the rust will swell in the winder an then its a sanner job behind the winder...................hope that helps
Old Sep 14, 2007 | 04:21 PM
xrmalin's Avatar
xrmalin
Theres a little spring clip behind the winder if you go to a local motor factors tell them what your doing and they will give you a special tool to do it and tell you how to use it hope that helps mate.
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
Bailes1992
Sep 3, 2015 02:17 PM
no1trancefan
Aug 4, 2015 12:48 PM
