efi blocks, mfi engine blocks whats the difference???
hi people, whats the difference between an efi and the mfi engine blocks?
are they inter-changable ie mfi head with efi block and vise versa?
just wondering as my bottom ends gone and a mate has a good efi rst block.
thanks for any info
thanks for any info
they are interchangeable but the crank position sensor hole is not present on nearly every mfi block.
apart from that as far as i'm aware there identical.
also gives u the option to go efi at a later date if u fit the flywheel from the efi rst aswell
marky_g
Aug 15, 2015 10:43 AM
Zoggon
Aug 10, 2015 10:39 AM
