Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Zetec Pulse Air Pipes
Old Sep 3, 2007 | 08:12 PM
orion18ghia's Avatar
orion18ghia
Default Zetec Pulse Air Pipes
I just bought a 4-2-1 manifold and de-cat pipe for my orion 1.8 and on the cast manifold it has allocated holes for he pulse air pipes but the new one does not, can i remove or move them elsewhere, PLEASE HELP ME URGENTLY NEED TO GET RID OF THAT NASTY CAT AND CAST MANIFOLD
Old Sep 4, 2007 | 05:11 AM
Take the pulse air off, it is only there to admit air to the exhaust system when cold to promtote continued burning inside the exhaust for good emmisions.
I took it off the mondy I had and the car was so much easier to work on, noticed no difference in performance at all.
Old Sep 5, 2007 | 10:41 PM
phill295's Avatar
phill295
egr system it not for performance it helps emmisions and as above so up to you if you want to keep it mite affect next m.o.t thou
Old Sep 6, 2007 | 06:03 AM
EGR and PULSE AIR are TWO ENTIRELY DIFFERENT SYSTEMS, and use TWO ENTIRELY DIFFERENT SET OF PIPES.
EGR is for performance as it reduces the combustion chamber temperatures to reduce emmisions of NOX, a gas that is emitted when certain temperatures are reached.
The EGR does no harm to performance at all as it turns off when at full throttle anyway, IF GOING RIGHT.
If having trouble just take off as it clears a lot of piping out of the way, but will not harm performance leaving on.
Make sure that you leave the EXHAUST GAS PRESSURE DIFFERENTIAL SENSOR connected(electrically) though other wise it will go into LOS, on SOME FORDS.
Old Sep 6, 2007 | 11:27 AM
orion18ghia
Default TABETHA!!!!!
Tabetha. removed the pipes and cast manifold but left evrything else where it was. But now need a new starter, starter wire and heat wrap and it earthed out on the new manifold and burnt out as they only mm's apart but been told the mk3 fiesta or the Ka starters are smaller and may give more clearance between the 2! Thanx fr all your advice it has been excellent! I know about the egr and was told to definitely NOT to touch this or i would face major problems!
DixieTheKid
11
Jun 6, 2020 11:20 AM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
Chopshop85
Sep 18, 2015 06:13 AM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
