Who uses bleed valves?
Old Aug 23, 2007 | 07:20 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Default Who uses bleed valves?
Just wondering, as aabout 6 months ago i took my car to jamsport, they chipped it, -31 and put a bleed valve on, 16psi, 169bhp and 202 lpft. Standard everything else and been fine for 6 months.
I thought it was normal to use a bleed valve for stage one?
Just that i went on my local rsoc and someone told me that they shouldnt have used a bleed valve and there crap and i should chuck it in the bin. And then said i should use the correct things to get 16psi without a crappy bleed valve.
Then some else said jamsport did his rst van and got 15psi without bleed valve....
So first thing why did they use a bleed valve on mine and not his?
And second thing is what should have been used instead of a bleed valve?
Old Aug 23, 2007 | 07:38 PM
project rs's Avatar
project rs
you can do it either way with bleed valve or by trial and error with amal valve connected and adjusting actuator to get desired boost. but if you then upgrade to say a large front intercooler and want to up boost bleed valve is instant getting amal and actuator to right boost could take hours which you wouldn't want to pay for. there's nothing wrong with bleed valves so long as you LEAVE them alone once set up
Old Aug 23, 2007 | 07:40 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
The lad that was saying he has not got a bleed valve also says he hasnt got amal valve either, how does this work?
Old Aug 23, 2007 | 09:31 PM
Fiecos Dan's Avatar
Fiecos Dan
Bleed valves are fine, as long as locked off with wire after setup, to stop fiddleing.
i use them on all mu cars if needed.
Old Aug 23, 2007 | 10:00 PM
addiction's Avatar
addiction
agreed absolutely nothing wrong with bleed valve's when set up correctly!
Old Aug 23, 2007 | 10:13 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
So why the f*ck is this bloke moaning at me about then?!?!
Old Aug 23, 2007 | 11:43 PM
Billy_RS's Avatar
Billy_RS
Tell him to shut up.
Setup using a bleed valve is fine. Just dont play around with it.
Old Aug 23, 2007 | 11:46 PM
BRAMMER's Avatar
BRAMMER
The amal valve was fitted to the cars from the factory as a electronic bleed valve to prevent over boost, so if your running above standard boost its no good really, also a bleed valve is fine if its left untouched, its when you get juvenile planks winding it out to race their mate, you get what i mean.
Old Aug 24, 2007 | 11:12 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
I would never have one as personal preference than any other reason, I must admit I have a bad opinion of them
Old Aug 24, 2007 | 12:04 PM
matt p's Avatar
matt p
Why is that?
As above really, only really needed to bypass the anal valve
Just makes the whole setup process easier and saves you money
Tell your mate tp shut up if he does not, slap him with a wet trout!
Matt
Old Aug 24, 2007 | 12:11 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Agree with the other comments: if it's set up correctly and not fiddled with then there's no problems having a bleed valve fitted.
Old Aug 24, 2007 | 12:30 PM
T28 RST's Avatar
T28 RST
Ok then
Ive had one on mine for 5 years without any hassle apart from when some fool decided to give me an extra 5 psi at one of the shows
Get it set and leave it alone, do that and you wont have any troubles.
Old Aug 24, 2007 | 01:05 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Yeah thats what i thought to b honest, got some boost hoses coming tomorrow so once v fitted them think im gna get booked into jampsort for another set up any way.
Cheers lads
Old Aug 24, 2007 | 01:41 PM
matt p's Avatar
matt p
Good lad may see you there
Old Aug 24, 2007 | 01:50 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
You work there?
Old Aug 24, 2007 | 02:36 PM
matt p's Avatar
matt p
Just help out a abit mate, mainly at weekends learning bits of jamie and the boys...
Proper laugh there, and they taketime out to show and tell you aswell, top bunch of people.
Was funny when comedy dan used to work there
The bike with no chain and the potatoe rocket cannon spring to mind
Old Aug 25, 2007 | 02:02 AM
Turbocabbie
Top Cab !!
Originally Posted by matt p
Why is that?
Because even if the vehicle owner does not play with it others do as stated elsewhere in this thread and because of that I do not like them.
Old Aug 25, 2007 | 08:09 AM
Fiecos Dan's Avatar
Fiecos Dan
Thats why i lock mine and other i set up with locking wire.
But people can still play around with other boost controll systems, by removing the boost/vac pipe.
Old Aug 26, 2007 | 12:41 PM
rst in breaking's Avatar
rst in breaking
Why is that?
Matt
Old Aug 26, 2007 | 01:52 PM
Oranoco's Avatar
Oranoco
There's nothing wrong with the bleed valve only the moron that tinkers with it once it's set up
Old Aug 28, 2007 | 10:23 AM
SafeChav's Avatar
SafeChav
The only issue that is more often than not overlooked with fitting bleed valves onto RST's is that you should only ever use a 3 port bleed valve if you still run MFI.
Other than that as everyone has said, it is perfectly acceptable and safe
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
markk
Sep 9, 2015 08:11 AM
