Ahmed Bayjoo chip at Burton Power
Old Aug 6, 2007 | 08:35 PM
joo5ty's Avatar
joo5ty
Default Ahmed Bayjoo chip at Burton Power
Hi guys,
I just orderd the Fiesta RS Turbo Bayjoo Chip on the Burton Power website. There modelnumber is CHIPFRST.1
They call it a stage 1 plug in module. I told them I have an OFAB ecu and it was no problem. A plug in module sounded very easy, but im having a bit of doubt if the chip will fit my needs.
My car has a large front mount intercooler. A larger hybrid turbo. Kent 35 camshaft and beige injectors.
I would like to run 18 psi of boost.
Will this chip work for me?
Old Aug 7, 2007 | 07:08 AM
As you have drastically changed the fuelling requirements, unless the chip has been written for that then NO it won't be good, you need it live mapped unless you can get a chip for the same mods that has been written by someone already.
Why not phone STU at MSD.
Old Aug 7, 2007 | 09:42 AM
joo5ty's Avatar
joo5ty
Darn, I was wondering about that.
They told me there is only 1 bajoo chip and it will work with my beige injectors (running 18psi).
I asked why they call it a stage 1 if there is only 1 kind of chip... there wasnt a clear anwser.
Old Aug 7, 2007 | 09:52 AM
bud-weis's Avatar
bud-weis
Football Cwazy
Beige injectors will struggle to do 18psi too i reckon...they will be maxed out.
Contact Motorsport Developments, i'm sure they can supply you with a proper chip that will work and make the car drive nicely, and be fast too.
Old Aug 7, 2007 | 09:56 AM
Neil@FastFord's Avatar
Neil@FastFord
I dont run 18 psi on mine.....when it works.
Whats the full spec? Or is that it?
You need to limit it to 15psi max i reckon, Bud-weis is right, you'll be pushing those Bieges pretty hard there.
Old Aug 7, 2007 | 10:20 AM
joo5ty's Avatar
joo5ty
block is rebuild
low compression 8.0:1
kent 35
hybrid turbo .48
beige injectors
ok so I understand 18 psi is a lot, but can it handle 15 psi...
I really start having doubts about the burton power bajoo chip..
they just sell the chip as a standard product instead of asking about the car specifications..
Old Aug 7, 2007 | 10:28 AM
Stu @ M Developments's Avatar
PassionFords Creator
No way will it be safe with a .48 T3.
BTW, this is NOT Ahmeds fault, his product is fine, when used within HIS guidlines, and i am absolutely certain this is outside them.
Old Aug 8, 2007 | 07:37 AM
joo5ty's Avatar
joo5ty
shit
well this is pretty stupid of me ofcourse, but I also think its a shame they told me it will work...
lets hope i can cancel the order and they will give me my money back..
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
