Rising rate fuel pressure reg - where from?
Old Aug 6, 2007 | 02:21 PM
Garage19's Avatar
Garage19
Default Rising rate fuel pressure reg - where from?
I need a rising rate fuel pressure reg for a project i'm working on at the mo.
Anyone know where i can get one from?
Thanks,
Doug.
Old Aug 6, 2007 | 02:48 PM
The DIVA's Avatar
The DIVA
http://www.suprastore.com/aefuprre.html
Try this place Doug,have dealt with them quite a bit....
These reg`s are the daddy too..
Old Aug 6, 2007 | 02:52 PM
Garage19's Avatar
Garage19
Cheers Diva. Looks good, but not rising rate unfortunatly
Old Aug 6, 2007 | 02:53 PM
The DIVA's Avatar
The DIVA
Fuel pressure will rise on a 1:1 ratio when referencing boost.
Old Aug 6, 2007 | 03:01 PM
Garage19's Avatar
Garage19
It says the pressure will rise... not that its rising rate.
1:1 is a normal reg that raises or lowers fuel pressure on a 1:1 ratio with plenum pressure.
I need something like a 1:1.2 ratio.. a rising rate.
Old Aug 6, 2007 | 03:05 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Diva, he means that as boost increases, ie the differential between boost and fuel pressure as well, so it is more at a bar than it is at idle etc, ie it rises rather than is just maintained
Old Aug 6, 2007 | 03:08 PM
Garage19's Avatar
Garage19
Correcto mundo!
Prob is i can't find any for sale apart from one in the states for $260.
Old Aug 6, 2007 | 03:17 PM
ECU Monitor Enthusiast
NEVER use these on a turbo car with EFI unless its completely remapped !!
Highly UNRECOMENDED IMO
Old Aug 6, 2007 | 03:22 PM
Chip's Avatar
Chip
Im sure Doug knows what he is doing
Old Aug 6, 2007 | 03:24 PM
I am sure he does, my remark was for those who arent as able
Old Aug 6, 2007 | 03:27 PM
Chip's Avatar
Chip
Fair enough, although given that someone as clued up as the diva didnt even know what a rising rate reg was, I doubt many people on here will be intending to fit one as they all wont know what one is either, lol
Old Aug 6, 2007 | 03:37 PM
Garage19's Avatar
Garage19
There is no need for them usually but this is a special situation.
Its not actually for a car. Its for the bike shown at the bottom of the page in the thread below.
http://www.turbosport.co.uk/showthre...ighlight=z1000
The injectors will be too small and all i have to change the fuelling is a Powercomander 3 which gives basic control of an aplpha-n map and not alot more.
I can't replace the injectors for bigger or turn the fuel pressure up as it will bugger up alot of other parimiters like warm up and accel enrich that i cannot re map.
So the plan is to use the best comprimise which is a rising rate FPR that will only increase the flow of the injectors up top when on boost and therefore shouldn't effect the other parimeters so much.
All a bit bodgy and not the way i would do it, but my mate only has a small budget and therefore i have to find the solution to fit the cost!
Old Aug 6, 2007 | 03:45 PM
The DIVA's Avatar
The DIVA
Sorry mate,totally read your question wrong
Just automatically assumed you needed a rising rate with boost to keep the fuel pressure matched......
Old Aug 7, 2007 | 11:43 AM
Garage19's Avatar
Garage19
No probs mate. It's sometimes confusing as people often refer to a FPR that will compensate for positive pressure as rising rate when in fact it isn't.
RB26DETT
Feb 5, 2022 01:54 PM
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
