3 door front hubs.. ?
Old Aug 5, 2007 | 09:14 AM
gibbo frst's Avatar
gibbo frst
Default 3 door front hubs.. ?
hi.. im sure that i read somewhere that the 3 door front hubs are an upgrade for the saff and was wondering what this actually does... thanks..
Old Aug 5, 2007 | 09:44 AM
Ginge !'s Avatar
Ginge !
just finding my feet
pm mike rainbird, he explained it to me once
Old Aug 5, 2007 | 09:53 AM
gibbo frst's Avatar
gibbo frst
so do you think they are worth having if cheap enough.. as i can get some cheap... to go on a 2wd saff...?
Old Aug 5, 2007 | 09:54 AM
Ginge !'s Avatar
Ginge !
yes deffo, its a handling thing and deffo worth it if they cheep
besides means you can sell them on for a profit after too
Old Aug 5, 2007 | 09:56 AM
JjCoDeX75's Avatar
JjCoDeX75
The knuckles are different. If you change the hubs, your current TCAs will no longer fit. As such you need to either change the TCAs as well with 3dr items, or more sensibly buy the adjustable TCAs from Mike Rainbird at the same time
JJ
JjCoDeX75's Avatar
JjCoDeX75
To add - makes the car turn in better on a track etc, but also makes the car a little more twitchy at speed.
JJ
Old Aug 5, 2007 | 10:05 AM
gibbo frst's Avatar
gibbo frst
ok no worries.. is £30 the pair a good price..?
Old Aug 5, 2007 | 10:16 AM
Ginge !'s Avatar
Ginge !
yes mate,,,,, they sell for 150 quid
Old Aug 5, 2007 | 10:20 AM
gibbo frst's Avatar
gibbo frst
good so a bargain price then... thanks for the help.. they are only 20 mins aay too,..
Old Aug 5, 2007 | 10:56 AM
JjCoDeX75's Avatar
JjCoDeX75
Sounds good matey! Make sure you get a set of brand new bearings and strip and overhaul them before fitting (you know it makes sense!). Make sure you are buying the right thing also - Check the knuckles.
Adjustable TCAs are a little dearer, but well worth the money
JJ
Old Aug 5, 2007 | 11:02 AM
gibbo frst's Avatar
gibbo frst
is their much difference just by looking at them.. ? they wont be going on the car yet as only got 2 month tax left and ill take off the road again for winter.. .. could you tell if they are the correct ones from a pic.... ?
Old Aug 5, 2007 | 11:24 AM
If you also put on a 3 door front roll bar, on a 2wd sapph/hatch it gets much better also, as I did all the time.
Old Aug 5, 2007 | 12:16 PM
JjCoDeX75's Avatar
JjCoDeX75
It is all about how the TCAs fit to the hubs. On the 3door, they have a thread and nut. On the saphs, they have a different configuration. If you post a photo, I would prob be able to tell as long as you have a close up of the knuckle where the TCA fits.
Tabetha
I never realised about the 3 door AR Bar - Big difference then?
JJ
Old Aug 5, 2007 | 12:21 PM
gibbo frst's Avatar
gibbo frst
http://i10.photobucket.com/albums/a1...o4k/a356_3.jpg
Old Aug 5, 2007 | 12:23 PM
gibbo frst's Avatar
gibbo frst
ill put another pic up when i get them but even if they are not 3 door ones ill just use as spares anyway...
Old Aug 5, 2007 | 12:59 PM
BIG difference, as it has less castor so is more twitchy, but grips better turns in better too, got to hold on though not very relaxing a bit like a mini/go kart for twitchiness!!
The other way is to use a spacer between the TCA bushes and the butt where it stops on the end of the roll bar thread.
I made some 10 + 15mm spacers like a "C" shape so you could just loosen roll bar/tca and insert then tighten up, so spacer goes between tca/bush and end inner stop/butt up of roll bar, so it pushes the wheel slightly further forward.
Old Aug 5, 2007 | 06:43 PM
JjCoDeX75's Avatar
JjCoDeX75
Interesting - I find that since I changed mine over and put on the Adjustable TCAs, mine is already pretty twitchy.
To be honest, I find the turn in so vastly improved, I am not sure if I would want any further twitchness.
I had intended to deal with the rear beam next, but your comments are most interesting.
JJ
Old Aug 5, 2007 | 06:45 PM
JjCoDeX75's Avatar
JjCoDeX75
http://i10.photobucket.com/albums/a147/gibbo4k/a356_3.jpg
Hi matey - they look right as far as I can tell from a photo.
Hate the colour choice mind! LOL
Definately do the bearings whilst they are out!
JJ
Old Aug 5, 2007 | 08:33 PM
gibbo frst's Avatar
gibbo frst
cheers . not sure if i will bother fitting them as i thought the car handled fine already ill either keep and fit next summer or sell them on... fed up of working on the car i just want to drive it..
leep27
Ford Mondeo Including ST
Aug 22, 2015 01:52 PM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
Old ford
Jul 31, 2015 06:50 AM
