fuel pump probs
Old Aug 1, 2007 | 09:17 PM
beef2001's Avatar
beef2001
Boost it
Default fuel pump probs
having probs with the fuel pump not making the arming up sound, im told fiesta rs has bad fuse boxes has anyone else had this inconsistent sound other day lost power temporarily now car wont even start i got one of those fse upgraded ones as well
Old Aug 1, 2007 | 10:20 PM
Wardy257's Avatar
Wardy257
Have you checked the relay at all? Have you volt droppped the pump?
Old Aug 4, 2007 | 12:44 PM
beef2001's Avatar
beef2001
Boost it
the AA bloke checked the relay the fuse box has melted a bit b4 where one of the fuses got hot apparantly the boxes in fiesta and escorts are notoriously terrible for loosening on vibration thus causing burning. the pump terminal under the seat was checked and theres power going to it so one can only assume the pumps mashed but ill know in the week as its at an auto electricians
Old Aug 4, 2007 | 12:59 PM
Oranoco's Avatar
Oranoco
Heard a lot of peoplesay Escorts and Fiesta's have issues with fuseboxes and injection relays but (*touches wood*) I've never had a problem. The injection relay is the same one that was in the car when I got it 11 years ago
Old Aug 4, 2007 | 02:59 PM
AndyKam's Avatar
AndyKam
I had the same problem with my FRST fuel pump. I traced the problem to the resister on the wiring just before the pump. I cut it off and connected the wire directly to the connector. No prblems since. Did this about 3 years ago now.
You cas see on the picture that the fuel pump wires have no longer the resister but instead are directly connected to the plug at the top.
Old Aug 6, 2007 | 06:19 AM
beef2001's Avatar
beef2001
Boost it
thanks very much for that, i guess if i get same probs ill need to jack the car and empty the fuel tank i guess the hardest bit is getting underneath to uncrew the pump how difficult is it , is it just a matter of getting a jack and a phillips screwdriver?
Old Aug 6, 2007 | 06:32 AM
beef2001's Avatar
beef2001
Boost it
also does those wires connect via spade connectors or did u just twist the wire
Old Aug 6, 2007 | 10:33 PM
AndyKam's Avatar
AndyKam
before you take the tank off check that you have power g'oing to the connecter at the top of the tank under your back seat. If youve got power there then you know its something to do with either the resistor or the pump its self.
I used spade connectors.
Andy
Old Aug 7, 2007 | 10:41 AM
beef2001's Avatar
beef2001
Boost it
I got the car back from the auto electricians, ill write whats written on the receipt to u.
CHECK FUEL PUMP CIRCUIT TRACE FAULT TO BAD EARTH ON FUEL PUMP BLOCK CONNECTOR REPLACE TERMINALS IN BLOACK AND CLEAN TERMINALS ON PUMP /SENDER UNIT
PLEASE NOTE REWIRE DIP BEAM RELAY
i guess the block connector is the one under the back seat right?
Old Aug 8, 2007 | 09:04 PM
cos jon's Avatar
cos jon
Cut that little black connector out the circuit , mine failed in the middle of town for that very reason !
Old Aug 11, 2007 | 06:15 AM
beef2001's Avatar
beef2001
Boost it
Hi, fuel pump probs agen im told theres no earth coming back from the pump after he tested the terminal under the seat, he says fiestas and escorts all have probs with pumps and that they are not good enough for the job I bought the upgraded fuel pump only a year ago.
Old Aug 13, 2007 | 06:37 PM
Wardy257's Avatar
Wardy257
Fit a new earth yourself, it is easy.
Old Aug 13, 2007 | 06:50 PM
beef2001's Avatar
beef2001
Boost it
yeh i had them do the work fitted a new block terminal and rewired an earth cleaned up the terminals etc, seemed to do the trick but it didnt work and broke down on me AGAIN 60 miles from home an AA charged me 95 quid coz i had wrong cover and auto electrician charged me 95 for the rewiring now I have to waitr till they get the car on the ramp so they can drop the tank coz apparantly u need 2 ft of clearance from the ground to get the tank out and i cant do this on jacks, maybe the uprated was too powerful and blew a wire off who knows or maybe after only a year the pumps packed up either way i wish they had built external pumps on these i know the petrol keeps em cool but...
Old Aug 14, 2007 | 10:01 PM
beef2001's Avatar
beef2001
Boost it
prob solved loose connectors theyve put new ones on and soldered them on shud be ok now
Old Aug 15, 2007 | 07:56 PM
frsjon's Avatar
frsjon
just seen this...can i ask the reason for the removal of the throttle damper from the top of the pump in the pic ??? did it have issues?? im interested as i think i have issues with mine...many thanks
Old Aug 15, 2007 | 11:42 PM
beef2001's Avatar
beef2001
Boost it
the prob i had was whoever fitted the pump used metal crimped to hold the connectors but when mixed with petrol this causes a reaction which renders the wires useless, some ppl are saying that cuttin off the black connector and wiring directly has solved their issues, hope this helps.
Old Aug 16, 2007 | 07:55 PM
frsjon's Avatar
frsjon
cheeRS for that but not what im on about....on the top of the pump should be the throttle damper which looks like those sweets from years back'flying saucers' its been removed from this pic...just wondering why
Old Aug 21, 2007 | 09:17 PM
beef2001's Avatar
beef2001
Boost it
i dsont know what the throttle damper does
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
