zvh 1.8 overheating on boost any ideas???
Old Jul 28, 2007 | 07:51 PM
BIGMATT1's Avatar
BIGMATT1
Default zvh 1.8 overheating on boost any ideas???
My rs turbo with zvh drives fine off boost but after a couple minutes hard driving on boost it overheats in a big way and blows all its water out. just recently had a new felpro head gasket and is running with a front mount cooler and alloy rad, you can drive all day off boost just overheating after or during hard driving i was thinking possibly a cracked head any ideas?? any help much appreciated, cheers matt
Old Jul 28, 2007 | 07:58 PM
dave_y's Avatar
dave_y
high oil temps? you got a gauge?
Old Jul 28, 2007 | 08:09 PM
mrviper's Avatar
mrviper
cracked head or block leting gasses past undr boost ?
Old Jul 28, 2007 | 10:29 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
headgasket felpro ones aren't great
Old Jul 28, 2007 | 10:35 PM
Šhatter Box's Avatar
Šhatter Box
there is your trouble
Old Jul 29, 2007 | 12:21 AM
BIGMATT1's Avatar
BIGMATT1
which head gasket is recommended, the car did this when i bought it so i replaced the bottom end as the engine got so hot it it sized the cam in the head and snaped the cam belt when i went to start it the next day,the oil pressure had dropped low i thought the whole problem was down to the oil pump been f**ked, i had the head repaired and skimmed before refitting
Old Jul 30, 2007 | 07:19 PM
Turbo Zetec
Engine Machinist
what did you have done to the head to repair it? the cams normally only sieze when the head is bent.
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
