cossie fuel pressure HELP!!
Old Jul 25, 2007 | 11:46 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default cossie fuel pressure HELP!!
i fitted a 044 fuel pump a while ago and set fuel pressure to 3.5 bar vac pipe off as it should be.
since then i have re wired the fuel pump power and earth, i thought it best to re check the fuel pressure as the pump was working much better with the new wiring,
i couldnt get the pressure below 4.2 bar, so i assumed the reg was faulty ,changed the reg, and i still cant adjust the pressure below 4.2 bar, if i put pressure on the small hose to simulate boost the fuel pressure raises fine, but if i put a vaccum on it, the fuel pressure will not drop
i think the pump is now making to much pressure? i have 13.5 volts at the pump, any ideas?
Old Jul 25, 2007 | 11:49 AM
jon@work's Avatar
jon@work
damaged/blocked fuel return line ?
Old Jul 25, 2007 | 11:51 AM
JTECH James
Passion for Fords!
i suppose that is a possibility, does the return just dump straight in to the tank? so i could take the fuel cap off and try an air line down it?
Old Jul 25, 2007 | 11:53 AM
JTECH James
Passion for Fords!
this proves how bad my old wiring was the fuel pump sounds like a jet engine compared to what it was like before
Old Jul 25, 2007 | 12:50 PM
jon@work's Avatar
jon@work
yeah - the return line feeds into a small bore metal pipe sticking out of the tank
Old Jul 25, 2007 | 03:00 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
check the fuel lines by the n/s jacking point they are often crushed by trolley jack operators.
If your fuel pump sounds like a jet engine you have a serious fault some where
Old Jul 25, 2007 | 07:11 PM
JTECH James
Passion for Fords!
it was a damaged fuel line, i must have caught it on something in the lanes where i live
thanks for all your help guys
JK12
33
Apr 26, 2021 12:09 PM
yatta
May 21, 2016 10:31 PM
dombanks
Sep 21, 2015 08:38 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
