how to set boost?
Old Jul 25, 2007 | 11:28 AM
R5FORD's Avatar
R5FORD
Default how to set boost?
iv put a new turbo on..how can i set he boost as i messed around with the actuator.. just basicall need to know how to..as its going for a dyno run on friday and iv gota drive the car down there
cheers
Old Jul 25, 2007 | 11:43 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Shorten the rod to increase boost, lengthen it to decrease boost
Old Jul 25, 2007 | 01:19 PM
R5FORD's Avatar
R5FORD
but how do i know how much boost its going to be running? and can anyone suggest how far i need the rod to be to get around 340ish on a t34.48?
Old Jul 25, 2007 | 01:20 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
you havent got a boost gauge????
carl
Old Jul 25, 2007 | 01:35 PM
R5FORD's Avatar
R5FORD
yhep took it all out..il re connect it now tho
Old Jul 25, 2007 | 01:40 PM
boXXer's Avatar
boXXer
GASH!
dont you need to make sure your car is fuelling ok for the boost setting on your new turbo? You'd need a wideband to make sure you dont melt it.
Then use your gauge to set it up.
Old Jul 25, 2007 | 01:45 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Rough guess 25psi maybe more - whatever your map requires I suppose
But you'll need your gauge in there first
Old Jul 25, 2007 | 02:17 PM
R5FORD's Avatar
R5FORD
its going down the tuners on frida mate..just wanted to know how to set boost really..the car was running way to rich for stage 1 so should be ok..but il take it teady all the way down to the tuners its about 20mins drive
Old Jul 25, 2007 | 02:18 PM
boXXer's Avatar
boXXer
GASH!
if its going to tuners, you dont need no boost at all. If its on yellows and stg1 chip, i wouldnt have it boosting at all, as the map will be for a T3 and not a bigger T34.
Old Jul 25, 2007 | 02:31 PM
RS500/364's Avatar
RS500/364
just put it on and make sure it keep the wastgate closed
like someone didnt do on here
and run it it will be set up by ur tuner
Old Jul 25, 2007 | 03:00 PM
R5FORD's Avatar
R5FORD
iv done all the work its got greens 3 bar etc..the tuners just going to set the fuel
Old Jul 25, 2007 | 03:07 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
I would advise you to let them set the boost too
What wastegate actuator are you using and what form of boost control have you got
Old Jul 25, 2007 | 03:48 PM
bud-weis's Avatar
bud-weis
Football Cwazy
just connect everything up to how it was and let them set it up for you....you'll never get it right by guessing.
just drive off boost most of the way there, and also if it's been overfuelling then have an oil change when you arrive
Old Jul 25, 2007 | 10:09 PM
R5FORD's Avatar
R5FORD
ok no problem..il drive off boost down there and they can sort the boost and fuel..
im doing the oil change tonight
Old Jul 25, 2007 | 10:11 PM
mechanic28's Avatar
mechanic28
mines at 21psi and pushing around the 340 bhp mark
Old Jul 25, 2007 | 10:13 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
leave the boost low, not much pre load on the wastegate actuator arm, then let the tuner set it on the rollers
Old Jul 25, 2007 | 10:20 PM
mechanic28's Avatar
mechanic28
good tuner should set it through your amel valve
Old Jul 25, 2007 | 10:23 PM
JTECH James
Passion for Fords!
how
Old Jul 25, 2007 | 10:26 PM
mechanic28's Avatar
mechanic28
i dont know just know my boost is control through my amel valve they set my actuator to a certain load then programmed my chip to make the amel valve control the boost plus they adjust the holes in the valve but that was when they was live mapping it
Old Jul 25, 2007 | 10:29 PM
JTECH James
Passion for Fords!
the spike is controlled by the amal valve, and the resrictor port is removed so the valve can get rid of enough air as it will be much more than it was designed for, but the boost(hold fig) is adjusted by the pre load on the wastegate actuator arm
Old Jul 25, 2007 | 10:32 PM
mechanic28's Avatar
mechanic28
dont know fella all i know when they come back from the fnal road test they said it was still running lean at high rpm so ahmed reprogrammed to chip to reduce the boost via amel valve
Old Jul 25, 2007 | 10:34 PM
JTECH James
Passion for Fords!
strange at high rpm the valve is normally closed anyway, sending all the boost from the compressor housing to the wastegate actuator ,so it opens at the gate set ammount, i opening the valve will increse boost not lower it
Old Jul 25, 2007 | 10:35 PM
JTECH James
Passion for Fords!
Amal valve,or boost control solenoid as its sometimes called, this is how the ecu controls the amount of boost the turbo makes ,like an elactronic bleed valve in effect.
it also allows the boost to have a peak and hold figure, as the boost will spike when the valve is opening, then return to its hold figure when it closes off at the top of the boost range.
some people do away with them and just fit a bleed valve in between, but then you can only run the hold figure of boost and not have a nice spike to give a tad more torque where its needed
the amal valve basicly stops the wastegate actuator seeing the full amount of boost pressure coming from the compressor housing ,it does this by opening and closing a electronic valve, which bleeds some of the boosted air to atmosphere
take this example ,your wastegate actuator is set with a small pre load, and will open at 15psi.
the turbo is making 15 psi, so the wastegate should open preventing the turbo from making any more boost, BUT the amal valve is opening and closing very quickly allowing 5 psi to escape to atmosphere, all of a sudden your turbo is making 20psi before the wastegate actuator can see the 15psi it opens at. HERE IS YOUR PEAK FIGURE,
Then as the rpm climbs ,the ecu tells the to valve stop opening and it stays closed, the wastegate actuator can now see the full amount of boost made by the turbo and only allows 15psi before it opens the wastegate to prevent any more, HERE IS THE HOLD FIGURE.
__________________
Old Jul 25, 2007 | 10:38 PM
mechanic28's Avatar
mechanic28
__________________
Old Jul 25, 2007 | 10:40 PM
JTECH James
Passion for Fords!
i answered a question on the rsoc site ,and copied it as i couldnt be bothered to write it again
Old Jul 25, 2007 | 10:42 PM
mechanic28's Avatar
mechanic28
thats just out right being lazy
Old Jul 25, 2007 | 10:43 PM
JTECH James
Passion for Fords!
well im probably wrong anyway
Old Jul 25, 2007 | 10:45 PM
mechanic28's Avatar
mechanic28
dont know fella just saying what i saw and was told
Old Jul 25, 2007 | 11:59 PM
R5FORD's Avatar
R5FORD
im just confused lol
Old Jul 26, 2007 | 10:08 AM
boXXer's Avatar
boXXer
GASH!
lol. JUST LEAVE IT!
Old Jul 26, 2007 | 10:15 AM
R5FORD's Avatar
R5FORD
lmao im only young im learning lol
Old Jul 26, 2007 | 10:17 AM
boXXer's Avatar
boXXer
GASH!
lol, me too! i meant if its going to a tuner, just dont boost it up at all.
Old Jul 26, 2007 | 10:39 AM
R5FORD's Avatar
R5FORD
oo lol yh il do that then
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
markk
Sep 9, 2015 08:11 AM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
