map sensor question
Old Jul 24, 2007 | 05:07 PM
jonesymk2's Avatar
jonesymk2
Default map sensor question
would a faulty or wrongly wired up map sensor stop a car from sparking,its on an erst converted to efi ofab management
Old Jul 24, 2007 | 09:57 PM
jonesymk2's Avatar
jonesymk2
anybody
Old Jul 24, 2007 | 10:02 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Not it my experience it wouldnt.....no!!
Old Jul 24, 2007 | 10:07 PM
jonesymk2's Avatar
jonesymk2
ok then cheers its just my mate is having a bit of trouble with his erst,he hasnt got a spark,hes tried the edis module still nothing,tried the coil pack and leads still nothing,i think hes trying the crank sensor next,because he hasnt got a later spec block hes using a sierra cvh bottom pulley and cps,the only thing is that the cps sensor isnt directly in line with the teeth on the bottom pulley but it only over hangs by about 3mm so would that cause a problem atall
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
tib2220
Sep 14, 2015 12:33 PM
