My New Engine......Decent spec YB..have a look
Old Jul 13, 2007 | 08:57 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Default My New Engine......Decent spec YB..have a look
Just put my name to this engine, not going to say what I paid but it was a fair price for what it is....rebuilt 3600 miles ago with paperwork to prove, all receipts for work done etc...
CYLINDER HEAD IS GAS FLOWED AND PORTED
DB 10`S
BRONZE VALVE GUIDES PLUS NEW STEM SEALS
3 ANGLED CUT THROATS
MODIFIED INLET MANIFOLD MATCHED TO HEAD
WITH FUEL RAIL INJECTORS
KENT COMPETITION CAM FOLLOWERS
200 BLOCK
SUMP AND CROSS SHAFT
LOW COMP PISTONS
CLEANED AND POLISHED COMBUSTION CAMBERS
UPRATED STAGE 1 FAST ROAD CLUTCH
ENGINE REBUILT WITH GROUP A HEADGASKET AND TIMING BELT
L8 ECU & GOOD CONDITION LOOM + SENSOR PRESENT AND WORKING
What sort of power has this engine been built for do you think? I have a 5-bar map sensor and some 1000cc injectors on their way what kind of power could I acheive realistically with these cams etc.....I know its over 400bhp (which was my ballpark before this came along)...
Place your bets now!
Dan
Old Jul 13, 2007 | 09:01 PM
glancy2081's Avatar
glancy2081
what turbo
Old Jul 13, 2007 | 09:02 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Originally Posted by glancy2081
what turbo
That was going to be my question lol
Steve.
Old Jul 13, 2007 | 09:03 PM
SillyFezzaMk1
Rubber Rhino Crew
undecided as to what im going to use on my setup but engine comes with standrad 4x4 turbo...
I'm after what the lump is upto really with teh cams, followers, pistons etc...turbo can be chosen later after some consultation with my tuner
Any ideas????
Old Jul 13, 2007 | 09:11 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
surely the turbo will decide the bhp of the engine, with a standard 4x4 t3 i doubt it would make much more than 300-330 bhp at a push.
Steve.
Old Jul 13, 2007 | 09:13 PM
Ian M's Avatar
Ian M
not enough info to hazard a guess really.
comp ratio?
port sizes in head?
turbo?
etc!!!!!
Old Jul 13, 2007 | 09:14 PM
SillyFezzaMk1
Rubber Rhino Crew
not really mate, if i put a T90 (if there is such a thing) does that make it a 800bhp engine?
So regardless of turbo spec what is the engine capable of is the question im asking...i'm happy with 400bhp so anything else is a bonus really.
Dan
Old Jul 13, 2007 | 09:16 PM
Rhys's Avatar
Rhys
HOw long is peice of string tbh, as all goes down to who built your engine. Best persont o speak to would be who built the engine.
Old Jul 13, 2007 | 09:18 PM
abdr500's Avatar
abdr500
its low comp and has bd10 add a t38 you will see 400 bhp
Moonstone Steve.
yes with the right turbo it will be a 400 bhp engine
Steve
Old Jul 13, 2007 | 09:19 PM
SillyFezzaMk1
Rubber Rhino Crew
true true...but will someone answer the question please lol
Dan
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
so its basically a low comp engine with a ported head and BD10's? t3 = 330/340 max really, t34 .63 = 400hp at a push.
what injectors?
Old Jul 13, 2007 | 09:21 PM
Moonstone Steve.
Agree with Rhys also will it be a strong reliable 400+ engine?
Steve.
SillyFezzaMk1
Rubber Rhino Crew
MD cos.........
1000cc MSD injectors
Old Jul 13, 2007 | 09:23 PM
abdr500's Avatar
abdr500
well your group a head gasket will be the point were most wouldnt push past 400 bhp you will need to be wire rung to be able to use a group a head gasket to beyound 400 bhp with out fail multy layer shim would have been better ...its not a 500 bhp engine
Old Jul 13, 2007 | 09:27 PM
SillyFezzaMk1
Rubber Rhino Crew
good info cheers matey, was going to get it wire rung anyhow when it's stripped and inspected at my tuners...if he's happy then it'll go back together with a wire rung block....if he's not happy then it's rebuild time
I know its not a 500bhp engine....if its capable of running 400 then i'm happy as I got it (full setup) for a good price.
Dan
Old Jul 13, 2007 | 09:41 PM
SillyFezzaMk1
Rubber Rhino Crew
Would I squeeze 450 out of this spec with the right turbo? or am I in BD14 inlet territory then?
Dan
Old Jul 13, 2007 | 10:05 PM
abdr500's Avatar
abdr500
SillyFezzaMk1
i belive that if you used a bd14 inlet and used a better head gasket and use a good turbo i cant see why you wount be near 450/480 bhp
Old Jul 13, 2007 | 10:08 PM
SillyFezzaMk1
Rubber Rhino Crew
sweet!
Next on the list......GEARBOX
Old Jul 14, 2007 | 12:37 AM
Karl 3dr's Avatar
Karl 3dr
I've always been under the impression that cossie h/gaskets rarely fail around the firing ring, its normally around the oil/water galleries?
Which kind of makes wire ringing them pointless?
I could be wrong though?
Old Jul 14, 2007 | 07:49 AM
GUZZLER's Avatar
GUZZLER
you don't need uprated cams for 400bhp.
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
