Problem or Not?
Old Jul 13, 2007 | 05:15 PM
tocca's Avatar
tocca
Default Problem or Not?
Right guys, picked up a zetec engine for a conversion. Stripped off manifolds etc as they were not needed. When trning over i found a bit of water coming out of the exhaust port. When i took spark plug out number 2 had water in it. The engine has been standing under a sheet for a while. I got all the water out and spryed some anti rust stuff down the bores for now. The engine turns over fine etc. My question is, shall i strip the engine to check the bore for rust? Or shall i just leave it and take a chance? Engine feels nice by hand.. no notcyness etc.. Cheers
Old Jul 13, 2007 | 05:28 PM
Alvyn's Avatar
Alvyn
If the engine was fine prior removal then IT'S more than likely to be condensation and nothing to worry about!
just take the plugs out and pour some engine oil down the bores and keep turning it over for awhile as you have been and ONCE it's run drain out the oil and change the filter!
Old Jul 13, 2007 | 05:31 PM
tocca's Avatar
tocca
Engine was said to be running fine before removal. Front of car was hanging off anyways so i doubt it stripped it for engien failure It was about half a centimer of water in it, got it all out now. Im just worried its rusted the bore..
Old Jul 13, 2007 | 05:36 PM
Bore will be a bit rusted but not anything you can do about it anyway.
If it had 5mm or so of water, it is entirely possible the headgasket has gone, your choice but if you need to do it it is a lot easier now!!
Old Jul 13, 2007 | 05:38 PM
radiant red's Avatar
radiant red
take it apart mate freshen it up, wont take long
Old Jul 13, 2007 | 05:47 PM
tocca's Avatar
tocca
Not so much time, its somewhere to do it I literally have 1 meter by say 60cm of space. Weather aint helping at all.
Old Jul 13, 2007 | 05:50 PM
radiant red
It is shite weather and of course somewhere to do it does help. Wont rain forever mate. But then again it could be fine but i would like to see inside it if it were mine
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
