tyre pressures for track days
Old Jul 11, 2007 | 10:18 AM
pacificzetecturbo's Avatar
pacificzetecturbo
Default tyre pressures for track days
After reading a post about an off at donny, im now a bit unsure about pressures, im running 225/40/16 2 x R888 and 2 x Yoko A048's only cause i couldnt get another 2 toyo's at the moment, but anyway what would people reccomend they should be??
Old Jul 11, 2007 | 10:25 AM
Redkop's Avatar
Redkop
I use 5-7psi less in my tyres when I go on track. Normal pressure is 31psi.
Old Jul 11, 2007 | 10:29 AM
Luca's Avatar
Luca
Lukesville
Take everything your told about tyre pressure with a pinch of salt - some swear by higher pressure, others lower just make sure it doesnt get tooo high - the heat can add llbs easily especially at somewhere like a GP circuit.
Good choice in tyres ! I would go for standard settings mate run them at this for first session then on return to pits after drop the pressure back to standard psi.
Ive found this works best for me but you here of people dropping lots of psi. This works for the strip but not always for track.
The tyres your running have a strenghned side wall unlike a road tyre which will distort under extreme conditions so that will seriously help tyre handling.
Just see how they go but take a good digital tyre pressure guage.
Old Jul 11, 2007 | 11:58 AM
NUTS RuS's Avatar
NUTS RuS
As your running road tyres try to keep them (when hot) at an average recommended road tyre pressure.
30 ish should be fine on a cool / normal day
28 ish on a hotter day
Remember in the morning when they are cold they will increase during the first session so set them below this figure initially - and check them constantly during the day
Build up the pressure during the first 2-3 laps and remember the grip level on a cold tyre is a lot less so take it steady in the first few corners.
Old Jul 11, 2007 | 12:14 PM
Jim Galbally's Avatar
Jim Galbally
never a truer word spoken
Old Jul 11, 2007 | 12:53 PM
Rolls's Avatar
Rolls
Jim- Is that where you went into paddock flat out in 5th by chance? - if so, i think the tyres not gripping was just part of the reason
Old Jul 11, 2007 | 01:42 PM
Eagle's Avatar
Eagle
Super Moderator
i was running 55psi front offside and 50 psi front nearside at donnington with 40 on the rears last year and can happily state there was atleast a 50% increase in grip on my cheappppyyyyyyy road tyres
Old Jul 11, 2007 | 06:08 PM
markk's Avatar
markk
Old Jul 11, 2007 | 06:17 PM
Tony Ryan's Avatar
Tony Ryan
what were you driving a, a Fork lift ??
Old Jul 11, 2007 | 08:49 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
On R888s, follow Tony's advice I'd say.
Dropping from road pressures up to 10 psi works VERY well on R888s - by mid to end of the session the tryes will be probably normal road pressure of 5-10 psi higher.
Start on 35 psi and you'll be on 45 or more by the end
Si
Old Jul 11, 2007 | 09:38 PM
NUTS RuS's Avatar
NUTS RuS
As an guide 24-25ish cold will see around 32ish when hot.
Drop this un needed hot 2-3psi out as soon as you come in from the session - or ideally half way through it.
Leave set at that all day.
Or as Eagle found out - if you personally dont like it and you find something else that works for you then stick with it Even if your 1 in a million
We can only give a set-up guide from experience - your own experience will give you the guide from your seat
One thing - if it isnt right or dosn't feel right to you then FFS go and ask someone. There will be plenty people on your trackday with either a similar car or with greater experience. The organisers will often help too. They are not just there for track tuition they have vast experience in all fields.
JoeyBoyden
Jan 4, 2024 02:36 PM
jamie956
11
Aug 25, 2015 11:51 AM
Churtz
Aug 20, 2015 08:12 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
