easiest way to remove saph foglamps + 500 cooler
its not getting full boost and me coolers swollen at the top when they bulge
so as i got a palce at the end of my street who car presure test it i may as well have that looked at whilst im there
think its a fauly amal though, may me a sensor as its started running like the amals unpluged again
car aint going anywhere either till the wheels sorted to may as well whilst its off the road
yeah they to swell at the top, guessing it might be fooked, wanna have it tested just incase
its very comon hence why they strap it in the middle, shame it still bulges inbetween anyway
just take the 2 bolts out of the rad (bolts to the under side of the shassis rails) and drop it down carefully (and you won't need to remove the water hoses if someone helps you)
Then once thats clear, undo the 2 bolts on the 500 cooler (again from underneath) and it will drop down and come out from underneath.
Fudgey
Sep 17, 2015 01:06 PM
Si B
Sep 12, 2015 06:49 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
