Can someone explain something to me about V8s?
PassionFord's crazy fool!
I was just thinking today, that V8s are usually two banks of 4 cylinders with the one cam per head, right?
Well modern 4cyl engines are twin cam per head.... how come this doesn't get used for V8 heads? Would it be a nightmare to implement?
Or am I missing a very simple answer??
Guest
Posts: n/a
I knew there would probably be some somewhere but they're not exactly mainstream are they? What's the reason for this?
Do the quad cams make mor epower in general?
errr, what v8 engines are there on the market?
i can only think of the audi series of v8's and the ford v8 from the mustang?
fords is probably the same design from the 1960's and the audi lump is quad cam.
I think the V8s in the MG ZTs are twin cam, not quad cam.
Of course the engine probably isn't classed as modern
Hey I'm here to learn, what can I say.
Thanks for the info
Thanks for the info
There are very few car manufacturers that DON'T make V8s
and people can wank off all they like about how many cams an engines got, it dont matter a shit, its how strong and powerful the fucker is for the money spent, and the pushrod single cam fuckers still pretty much rule over most stuff you can get on the market no matter how flashy it is.
A single cam V8 can make more power than quad cam V8, if it is tuned that way.
The reason why most newer engines in general are twin cam(4 cyl) or quad cam V8 is to do with VALVES.
The more valves you can get in the chamber the better the emissions and power can be made, two smaller inlet valves delivering a consequently higher port velocity than a single big one will produce more torque, and have better tractability.
With this in mind it is easier to arrange a seperate cam for each set of valves, due to space in the head design.
Of course some engine don't have cams at all, some have aspin valves are so are desmodromic drive, VERY VERY few though, never seen one just read about them.
Originally Posted by Jim Green
M5 Quad Cam, Variable inlet and Exhaust Timing....about as advanced as you can get.........Lots of quad cam V8's out there....Ford Mustang 4.6ltr..Quad Cam......Where have you been..
Not too sure about the big-block ones though......
here's a single cam V8
http://www.youtube.com/watch?v=yT_VHmUijV8
and a quad cam V8
shame the sound's crap, but you get the idea
http://www.youtube.com/watch?v=XAcdg...elated&search=
and a quad cam V8
and the best sound i think, quad cam with super charger
http://www.youtube.com/watch?v=2lQX3...elated&search=
JK12
33
Apr 26, 2021 12:09 PM
Sheepdisease
Aug 30, 2015 09:11 PM
