In search of enlightenment(not the spiritual kind)
Old Jul 10, 2007 | 01:32 PM
Tee from China's Avatar
Tee from China
Default In search of enlightenment(not the spiritual kind)
Ni hao(Chinese greeting) I need some understanding of YB exhaust manifolds.
I see ads for Sapphire Cosworths in 2wd fitted with 4Be exhaust manifold and ads for 4BE's with 2wd exhaust manifolds.
Is it safe therefore to assume that a 2wd with run better on a 4BE manifold and a 4Be better on a 2wd one - or is this a load of b*@@*cks?
And whilst on the topic of exhaust manifolds - which is better tubular or cast? Performance wise and cost wise!
Xei xei ne (Chinese thank you)
Old Jul 10, 2007 | 01:43 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
2wd saph is preferred option for some people wether on 2wd or 4x4
Old Jul 10, 2007 | 01:52 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The 2wd manifold suffers from NVH problems, hence why it has to have a turbo damper on it. However, it is very efficient given that it is on a 204bhp car, as it doesn't actually become restrictive until 580bhp .
To overcome the NVH issues, Ford redesigned the manifold and this was then fitted on all the 4x4 cars. However, due to it not needing a turbo damper, the mounting point for this was no longer necessary, so was deleted from the 4x4 heads. Unfortunately, although the design eliminated the NVH problems, it lowered the power out-put of the restriction point to well under 500bhp (YUM's car did 466bhp with one, which is as much as I would want to push one to). Despite this, low down torque is alleged to be slightly improved due to the smaller internal diameters of the headers giving better gas speed to the turbo.
Now you can probably guess from the above as to why you see them swapped between head / transmission types - it all depends on what numbers you are chasing .
Cast manifolds seem to have a greater durability than their tubular brothers, but the tubular ones can be made to give very exacting power characteristics and it's a lot easier to get an equal length with this design in a particularly confined space compared to a cast item. To have one cast would actually be more expensive for a one off compared to a tubular one, but once the mould has been made, they can be banged out far more cheaply than a hand-made tubular item.
Old Jul 11, 2007 | 12:35 PM
Franco's Avatar
Franco
Whats NVH mean Mike?
Old Jul 11, 2007 | 12:38 PM
James's Avatar
James
noise harshness & vibration
Old Jul 11, 2007 | 12:40 PM
Franco's Avatar
Franco
Ahh okay.
Cheers for that!
locum8
Oct 1, 2015 01:50 PM
Fiddy
21
Sep 29, 2015 06:10 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
Bransby
Sep 21, 2015 05:29 PM
Brickhouse
Sep 21, 2015 04:31 PM
