Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
RS2000 slight missfire, no loss of power tho
Old Jul 10, 2007 | 12:50 PM
fast_ford_uk's Avatar
fast_ford_uk
Default RS2000 slight missfire, no loss of power tho
hi guys, my rs2000 has a slight missfire but this doesnt effect the performance atall
ive checked the leads, plugs, compression, power to coil packs
my next thought is injectors, any ideas
Old Jul 10, 2007 | 08:42 PM
rs_daz's Avatar
rs_daz
Id say a coil pack .. Sometimes they break down under load.. you cant test them..
Guy on ebay sells them cheap..
Old Jul 18, 2007 | 05:19 PM
fast_ford_uk
why cant you test them, you can measure the resistance to test for an open circuit
Old Jul 19, 2007 | 02:36 PM
Barry R's Avatar
Barry R
wheres te turbo?
Old Jul 20, 2007 | 08:58 AM
danrs2k's Avatar
danrs2k
i had this problem with mine it turned out to be the 2 ht leads. I replaced them for some thick core ones n neva had a problem since.
*goes and touches wood*
Old Jul 20, 2007 | 08:27 PM
Dave Parker's Avatar
Dave Parker
get the injectors checked or
Old Jul 20, 2007 | 10:21 PM
Wardy257's Avatar
Wardy257
You can test the coil packs just like you check a normal coil.
Old Jul 22, 2007 | 01:26 PM
fast_ford_uk
Originally Posted by Barry R
wheres te turbo?
the cam in the head you sold me was fuked mate, the rs2000 is just my runaround
fast_ford_uk
will try a new set of leads cheers guys
Old Jul 23, 2007 | 03:49 PM
fast_ford_uk
if the piston rings were gone i would loose performance. and theres no lose of compression,
Old Jul 23, 2007 | 04:27 PM
Dave Parker
that happened with no miss fire just more or less stalled a bit lumpy then nothing no warning running sweet as
Old Jul 23, 2007 | 04:35 PM
fast_ford_uk
fuk ever find out the cause? thats got serously hot
Old Jul 23, 2007 | 05:17 PM
Dave Parker
the engine was completely fucked was doing about 50 mph when it just slowed down no miss just no power then went lumpy and stalled, when the head was off that had a crack and the bore was smeared with melted piston but there was no advanced warning at all nothing. mind you it had done 130,000 so i broke it up. when checked we were told that a partly block injector let it get so hot and that was it no bang nothing couldnt believe it never mind
Old Jul 24, 2007 | 05:21 PM
fast_ford_uk
air injector?
Old Jul 24, 2007 | 07:03 PM
Dave Parker
no number 4 fuel injector
Old Jul 25, 2007 | 04:53 PM
fast_ford_uk
Old Dec 9, 2007 | 08:08 AM
Mark_'s Avatar
Mark_
Default rs2000 missfire
i had the same problem a few months ago. it turned out to be the wires that go to the coil packs. the had small breaks in the wires. the proplem being that the wires are part of the engine loom and can be difficult to find a replacement unless you get one custom made for around Ł300. i took mine apart and managed to repair the dodgey bits which was a task on its own
Old Dec 10, 2007 | 11:21 AM
fast_ford_uk
problem solved - after starting fresh, doing all the basic checks i done another compression test - showed 40psi no. 1, done wet test which didnt change a thing - wipped off head, found a burnt out valve caused by overfueling. fit new valves - sorted
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Fil
Sep 30, 2015 12:08 PM
