How does Variable Valve Timing (VVTI) work ???
Old Sep 24, 2004 | 11:27 PM
AndyRST's Avatar
AndyRST
Default How does Variable Valve Timing (VVTI) work ???
and dont say it varies the valve timing, because i guessed that in the name of it
Can someone explain it (in a technical but easy to understand way please stu, karl, etc ) and how it acheives the varied valve timings on say a Focus ST170 ??
Old Sep 24, 2004 | 11:58 PM
philc's Avatar
philc
http://auto.howstuffworks.com/question229.htm
Old Sep 25, 2004 | 10:27 AM
Jim Galbally's Avatar
Jim Galbally
uses va va voom
Old Sep 25, 2004 | 06:15 PM
AndyRST's Avatar
AndyRST
So how does the cam timing adjust then ?
Old Sep 25, 2004 | 06:19 PM
Jim Galbally
without reading that howstuf works page...
cam has 2 sets of lobes (so say 8 valves, you have 16 lobes) in normnal running half of them are in contact with the valves, and have "normal" profiles... all's happy
when you start caning the shit out of the c the cam physically moves across a bit (so moves sideways) which will mean the normal profile lobes are no longer in contact with the valves, and the new more meaty lobes are touching the valves...
feck knows how it moves, or even if im talkin about the right type of thing (iirc vtec and vvti are actually different, not just different names for same thing )
but thats how i understand it
Old Sep 25, 2004 | 06:59 PM
Alps Pacino's Avatar
Alps Pacino
my crx vtec actually had 3 lobes and 3 rocker arms 2 big 1 little on the exhaust side per cylinder, and the cam does infact move across. Me and me mate took his head apart after he blew it up to see what the crack with the vtec was, and still couldnt work it out with the head infront of us. I think you need to look at it with slanty eyes to see how it works
Old Sep 25, 2004 | 07:04 PM
markk's Avatar
markk
lol !!
try by hydraulic pulleys (usually just inlet ) can work by oil pressure (early type oil pressure alone -simple on of ) tho not stricktly call variable valve timing , another way is to duty cycle a solenoid to create a pressure sensetive gallery to which the cam will be forced against a spring to advance or retard camshafts !!
Old Sep 25, 2004 | 07:10 PM
Dan B's Avatar
Dan B
This explains VTEC nicely, I thought:
Video-clip (2.4Mb)
Old Sep 25, 2004 | 10:33 PM
AndyRST's Avatar
AndyRST
Video-clip (2.4Mb)
Dan that video clip explains things really well, thanks for that!
Bailes1992
Aug 16, 2015 07:14 PM
Adam-M
22
Aug 10, 2015 10:46 AM
Red_bull
Aug 9, 2015 08:34 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
